Reserved.
Reserved.
What sort of Cd value is this putting out? 1000 metres is what my Olight M3XS-UT Javelot is rated at. And that is a de-domed XP-L with 250,000cd.
I’d assume a LED would have a much higher cd value? Or is it physically really tiny?
But yes I would either be interested in this or the WP2 depending on some more info.
WP1 is of a much smaller form factor with approximately 150mm in length than Javelot. You can see that spill is minimum (or some might even say zero spill) with LEP technology. You can expect similar results for our new WP1.
can we see how big is it when someone is holding it in their hand?
I’m IN if price is under $120. i am out for now
but this looks concerning.
_Throw Distance: 1000m / 0.621mi
User Interface: Low-Mid-High-Strobe-SOS mode Basic Modes_
LEP should do much better distance no?
i don’t want sos or strobe, ever… its annoying.
Im interested in the specs for the WP2
Interested in the WP2
interested in wp2 depending on specifications x price
Interested in wp2
That looks a lot like J e t b e a m :D
Also interested in the WP2.
The specs for the WP1 are impressive, for what essentially looks like a 21700 tube light. But I have lots of lights in that ballpark of throw. Whereas if the WP2 has specs similar to another light that it looks very similar to (already mentioned by someone), then it should have around 1.3Mcd, which interests me a lot! But as already mentioned, that UI is not desirable.
“Only confirmed buyers will receive our deals.”
What does this mean? How do I become a confirmed buyer?
Anyway, I would be in if the price is under $160.
I will regard you as a confirmed buyer if:
- Our group buy price is lower than what you specified in your reply.
- You are willing to make your preorder after you have received my discount code. Preferably within next 30 days.
Coupon harvesting is disallowed. Do not express interest if you have no intention of getting one from start.
Rear switch off/on and rotary switch to cycle modes which wouldn’t be a problem for sos, strobe
The WP1 has a tiny head diameter, we’d see a much greater range from the WP2.
Tell me, how many LED type lights can push that range at that size
Not M company.
WP1 Interested if below $125 if with USB-C charge.
Intradested below 120 , thx Freeme
I’m in for the wp2 if the price is below 220.
not sure if this thread is appropriate, but maybe freeme can post a comparison checklist to other lep? or in another thread by someone else is fine too? thanks.
