im selling something i bought on amazon in a second hand market, the buyer is asking for the gift receipt. is there anything i should be concerned about? like is there anything they can do with the gift receipt that can be linked back to me in a negative way?
You may get some thicker PCB and file them down to the desired thickness.
It’s a bit painful with copper, so for people who have them I’d recommend some Virence / Led4Power alu PCBs. These are hard to get nowadays though…
As far as I know, about the best they can do is attempt to return it to amazon for the original purchase price.
That said - in the secondhand market, if people want weird things, I usually just consider that it’s either too much trouble, they’re up to something, or both. Hopefully for you it’s an option to just move on to a less suspicious buyer.
Appreciate you trying to help. I have three in total: the S2 UV, an S2+ with 7135*8 driver and T6-4C XML2, and an S2+ with (if memory serves) a 7135*6 driver and a U2-1A XML2.
I’m not sure on the current handling, but if you search around BLF some you’ll find that all the UV LEDs can’t handle much heat, either. Even treated nicely they don’t have great runtime ratings. You can probably run them at 3A briefly and get lots of power - but, at least for all the examples I’ve looked at, you’re also going to need a 2 cells+buck driver or one cell and a boost driver to hit much current on them - the forward voltage starts high and ascends rapidly.
Thanks to Jason and Scallywag for their input on UV LEDs (I left it as is).
I just recieved an Emisar D4v2 with 3500k E21A emitters, I was wondering if it’s “normal” for them to immediately turn blue on turbo with a high drain battery?
I’m assuming that it has the Noctigon driver which delivers 5A on turbo.
Some of my 14500 batteries have a “pronounced” pip at the positive end and some don’t. I know the trick of using a small round magnet to make the pip longer. Is there something different about these batteries internal make-up? Is there any reason that thay are not all made to a standard length?
With my Olight Perun Mini, can I put one of those little magnets on the top and then safely charge it in a normal charger like my 18650s?
Pretty sure I can, just wanted to check…
Has anyone ever made a flashlight out of these 250-315nm UV LED parts, or these 275nm UV LED parts Or have a reference to a list of materials that can be successfully built and used in the 250/275nm range? Mod for a Convoy S2+ would be awesome but I don’t see a reference here or elsewhere.
