Does anyone know where can I find rubber replacement switch button cover for Skilhunt h02?
seriously?
i would try skilhunt.
why would you not do that?
wle
I tried but got no reply. Anyway a new flashlight was purchased several months ago. And that great customer service will be taken into consideration if I would want to buy Skilhunt again.
they are not cheap, i would expect decent american or at least responsive chinese service.
i replaced mine with 10mm silicone boot, from kaidomain, it is taller than oem, but it works fine, and it isn’t getting pressed accidentally, the press has to be pretty long. i also printed a quick release holder, the light can have its clip installed, it is not interfering with the holder, it is next to useless when installed backwards but at least it is always there, can be reversed easily if needed, with oem holder, it is either or,
Hey there, I was looking for ages for a replacement switch boot back in 2018 and 2019 and just saw your post. Are these the boot your purchased from kaidomain?, they currently only have 1 listing for 10mm x 8mm boot.
yep, that is the one
