What Legoes with What?
Hmm, you must be correct, there's a reason for it being called a "Mini", right.. ?
Which 18350 tube will fit?
https://m.aliexpress.com/item/826041411.html
A regular S2+ 18350 tube will do! I have one in mine!
Check this post: What Legoes with What? - #138 by MascaratumB
Does your S2 have the yellow/glow in dark tail click switch? Maybe Simon has changed the S2? S2
Simon still denies they will fit the S2
There are now two versions of the 18350, rectangular or trapezoidal
S2+ Gray/Black Tube
Mine came with a black rubber tailcap!
It was this one: 11.04€ |Convoy S2 taschenlampe host, umfassen OP reflektor, pille, kopf O ring,glas, frühling, lanyard|flashlight host|op reflectorconvoy s2 flashlight - AliExpress
The tube was the one you linked, and by that time there was no distinction :frowning:
Simon also said that to me at the time, but the tube fitted the S2 and the S2+ .
Is the bottom picture of your tube which fits the S2? Gray color? If so, I’ll ask others for help in identifying if it is rectangular or trapezoidal
I just checked and it is trapezoidal :wink:
EDIT: I have 2 of them and both are trapezoidal!
FWAA body can be used with Foursevens Mini Turbo.
In my case, it was FWAA TiCu and Mini Turbo Alu.
However it’s a bit useless to do so because the switch is an e-switch :smiley:
You can always try to mod the switch of the FWAA :wink: Not ideal, eventually, but it works :wink:
I did it with mine: What did you mod today? - #10350 by MascaratumB
Cool MascaratumB!
I think I’m gonna try that switch mod.
Last night my 14500 battery suddenly depleted.
Quick voltage check using Nitecore F1 charger shows only 2 volts but my VC2 charger says the battery is full :person_facepalming:
It makes my FWAA is practically not in use until I get a new battery. It’s not easy to find good one here locally.
Ha! This is a very nice find, I wonder how come I've skipped over it until now..
Anyways, I believe the proper fit should be for the tail switch versions, MT20C or MT10C:
Also, while not a straight fit, I've found that a C8 Mini version (Jaxman in this case - not all C8 minis might fit tho I suppose) with the need of a conductive ring/spacer would be a better proportioned fit with its thinner tube and tailcap.
Lumitop GTA with Lumintop Tool AA
The dessert…
The AA tool is Nichia 219C. Both with white Eneloop and in the highest mode.
The bezel from an Astro S1 / BLF A6 legos with Sofirn SC31(T).
I’m not sure how common these tins are around the world, but the plastic lid of my Lavazza coffee tins are a perfect fit as a protective cap for the Wildtrail WT90. But although it clamps, I will use two bits of cellotape as well because the WT90 bezel has no rim around the outside of the bezel for a firm clamping action, like the coffee tin.
V10r Ti+Al lol
Wow, look at that things pocket clip!
I made the handle myself, but now you mention it, it does not work so bad as a pocketclip :slight_smile:
:person_facepalming: :smiley: :+1:
Nice work!
Does anyone know if there are 18350 tubes for the S6? I clicked the link that edeekeos posted in this thread but it looks like the black tubes are no longer being produced. There are silver versions available but I would prefer the black.
There seems to be identical items on AliExpress but the seller ratings are pretty poor so I would like to avoid going that route and avoid the headache, even if it’s just items which are a few dollars.
Are there any other options I can look to for an 18350 tube for the Convoy S6?
If not, I guess I might try my luck on the silver tubes on Banggood…
Just found out that the switch of a Convoy S2+ fits into the Mateminco FW2 /Astrolux WP4.
