【convoy】H4 and B35AM options are updated
Indeed. :slight_smile:
Yeah Simon, keep us updated with that Upcoming L6 :smiley:
Excellent news. Does the 12V 4A driver have 12 group UI?
These 2 made me smiling for days. M21B is perfect host for XHP50.2 and new T2 is simply WOW.
Although description of new T2 say it’s 0.5A on AA and 1.5A on Liion, when running both chemistry on max setting, brightness difference is minimum. At least to me.
I just love it. Perfect size and bright as hell.
Well done Simon!
Do you have beamshots to share, please?
Hello Simon,
Did you get any update from your LED agent?
Tomorrow
Simon
You consider to do an AAA light with E21A 2000K?
Because this CCT does not harm the endocrine system and the sleep cycle,
and is perfect for indoor use.
We lack them.
ok ,i will add it in my plan
Awesome!
2020/12/22
I compared the flashlight with the L6 XHP70.2. From the naked eye, the brightness of the two is similar. I feel that this sample of mine is a little greenish, which should be due to the lack of red phosphor. Its light spot is relatively uniform, and there is no yellow-green on the edge of the light spot like XHP70.2.
I don’t have a spectrum tester, so I don’t know its true color rendering. If anyone has relevant test equipment and is interested in making a detailed review, please contact me and I will send samples for free.
I can test the L6 FC40 for output and color rendering. Please send me a private message. Can’t promise a full blown review, since I’m quite busy.
How quickly does a flashlight get hot compared to XHP70.2?
This is great! Thanks Simon for the update and willingness to develop lights we are interested in. And thank you to maukka for offering to test it!
This is a great opportunity for you Simon to reference your measurement values against Maukkas calibrated equipment, too!
Well,a small clicky light TIR lens 3/4modes (no strobe)
start 0,1 lm - 4 lm 25lm 100lm with reversible UI would be nice
with E21A 2000k
Simon, you should try the Luminus SST-70 with a 5A-6A driver in the L6. I installed one in my L6 and the beam is amazing. MUCH better than XHP70.2 and XHP50.2.
Simon, will you be releasing a conversion kit with GT-FC40 and driver for the L6?
I'm interested in driver only.
If 4A and it could fit M21C-U AND work on single-cell...hell yeah!
I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
The broad spectrum Green and Orange-Yellow emitters are very interesting as there is still some colour rendering across the whole spectrum.
Unfortunately, it seems that the Red LED driver doesn’t appear to be functioning correctly. Both 100% and 20% appear to have the same output, and it looks like the temperature protection isn’t working as this light runs considerably hotter than the others.
How long do you think the AAA flashlight cannot exceed?
