You mean the one directly next to one of the LEDs? This optic has what appears to be a chip, but it isn’t. They’re all like that. I thought the same thing when I got my first D4V2 (same optic)
Yep, directly next to one of the LEDs, at the edge. Thank you for clarifying that! I’m guessing it might be a part of the manufacturing process (e.g. where the mold is filled). I’ll edit my original post as well.
I bet you mean 10622 .
Edit 2020-12-18: Ignore this, I goofed at reading comprehension.
Normally the KR4 with E21A would be shipped with the 10622 optics, yes. However, this one is clearly not frosted. Based on the LED Supply’s Quad Carclo page , the only common quad non-frosted Carclo optic is the 10621.
Someone on Reddit had mentioned that Hank may have run out of 10622 optics. I had asked Hank via email about swapping optics as well, and given what I wrote I may have accidentally opted into the 10621.
However, I picked the warmer (2700K) E21A, so tint shift isn’t an issue and I do like having a bit more throw. I’m totally satisfied with this outcome.
(Of course, I’d have to buy another optic to make sure, and I could just get another flashlight… This may be my first purchase after many months of deliberation, but it probably won’t be my last.)
The frosted one is 10623 .
Ah, whoops. I think this is a sign that I should get some sleep. Thank you for clarifying!
This Hank is a teaser .
Excellent, most promising.
The size in hand looks perfect! Can’t wait to see the specs.
Pretty must-haveish. I wonder what colors will be available initially.
The white glove is a great idea. Makes it seem he is holding something very special.
keep em coming Hank!
oh and to stay on topic. here is my copper that just came in
Looks great, crenulated bezel as well!
Looks a good bit brighter green than my D1, D4, D4S.
I still need a green D1S, and not that chalky surface on the cyan.
Still no 219c option…
NOCTIGON K9.3 DUAL CHANNEL 7400LM 21700 LED FLASHLIGHT
That's a sic amount of choices - made to order...
Wait, what’s the best way to go about spec ing one?
SST 20 5000K centre
Maybe 2700k outer?
