An artist friend who works in glass told me that soda-lime glass (used for bottles and containers) requires careful heating to reuse.
i once used a hot-wire cutter to remove the necks of some beer bottles to make whisky glasses, but even with that the edges were too rough for drinking. She said they would need stress relief in an oven and even that would be no guarantee to add a lip with a torch without breaking.
The glass used in a lab is a different type and can be cut, drawn, bent and easily lipped with a bunsen burner.
Great work with bending and molding the plastic C-man.
Thanks everyone.
There are many bridges yet to cross before this one is done. It is fun to be here in the mix with everyone.
I initially thought this project would be quick and fairly easy, but instead it became trial and error at the start.
So next will be trimming to length and prepping for mounting the driver. Also a test of all electrical components prior to installing.
My hope is to inspire members to enter the contest and get involved in the forum.
Ok, back at the operating table we try to get a heart beat
Swapping a XHP 70.2 from a 20mm star.
I used an electric skillet set to 400 deg to remove and relocate the led.
Cutting out the copper mounting plate for the led mcpcb.
Drilled and tapped 2 x 2mm x .4mm holes for mounting screws.
Driver mounting ring.
After punching a .625 dia hole, it needed opening up to .690 diameter in order to fit the driver.
The momentary switch needed this resistor soldered on it to control the leds brightness. It was very tiny, almost invisible without magnification. It required a sharp pointed tip and steady hands.
JasonWW and gchart helped me by explaining the wiring connections on the momentary switch. It came with blue leds and the driver was not made for a switch with leds and this was my first time wiring one. I have modded lights that will get their lighted switches fixed now Thanks guys for Helping
More wires than driver
Mini-360 3A DC Voltage Step Down Power Converter for the cooling fan.
The phillips screw is the adjustment, clockwise lowers the voltage.
Adjusting the 5V setting for the cooling fan.
Ready to fire it up.
The switch leds and fan are on.
Now its ready to mount the driver to part #1 of the head and then to the battery tube.
The brightness does increase, the camera adjusted and it does not show.
Next up will be a switch housing and the heat sink assembly and fan mounting.
Now comes the fun part, making the heat sink.
Yrs ago I worked on jet engines, so I thought it would be fun to make it look similar.
Punching out the center to accept a copper plate that was also stamped out.
This was repeated for each piece.
Here are the blade disc that will draw away the heat.
Initially 4 sets of blades were going to be used, but it was going to be too long, so 3 sets fit better.
All the pieces layed out ready for stacking. The blade disks have .5 diameter copper inserts i\pressed in.
The copper spacer inserts are .75 diameter.
Stacked and prepped with reflow solder on the electric skillet.
Finished soldering as can be seen by the dab of melted solder on top.
You can see the reflow solder melted between the copper inserts making it a solid connection for heat transfer.
The mcpcb will mount on this side with 2 small screws.
Finished with mcpcb and fan mounted, ready to be installed.
Glue is drying overnight for the side switch.
Next up will be to finish the side switch and mount the heat sink.
