Simon
You consider to do an AAA light with E21A 2000K?
Because this CCT does not harm the endocrine system and the sleep cycle,
and is perfect for indoor use.
We lack them.
2020/12/22
I compared the flashlight with the L6 XHP70.2. From the naked eye, the brightness of the two is similar. I feel that this sample of mine is a little greenish, which should be due to the lack of red phosphor. Its light spot is relatively uniform, and there is no yellow-green on the edge of the light spot like XHP70.2.
I don’t have a spectrum tester, so I don’t know its true color rendering. If anyone has relevant test equipment and is interested in making a detailed review, please contact me and I will send samples for free.
Simon, you should try the Luminus SST-70 with a 5A-6A driver in the L6. I installed one in my L6 and the beam is amazing. MUCH better than XHP70.2 and XHP50.2.
I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
The broad spectrum Green and Orange-Yellow emitters are very interesting as there is still some colour rendering across the whole spectrum.
Unfortunately, it seems that the Red LED driver doesn’t appear to be functioning correctly. Both 100% and 20% appear to have the same output, and it looks like the temperature protection isn’t working as this light runs considerably hotter than the others.
