Simon, you should try the Luminus SST-70 with a 5A-6A driver in the L6. I installed one in my L6 and the beam is amazing. MUCH better than XHP70.2 and XHP50.2.
I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
The broad spectrum Green and Orange-Yellow emitters are very interesting as there is still some colour rendering across the whole spectrum.
Unfortunately, it seems that the Red LED driver doesn’t appear to be functioning correctly. Both 100% and 20% appear to have the same output, and it looks like the temperature protection isn’t working as this light runs considerably hotter than the others.
That’s awesome! Djozz tested the SST-70 and got 4000 lumen at 6 Amps. His lumens are a bit high, but the SST-70 matches the XHP50.2 in output up to 6 Amps. But then you get the increased throw and hardly any tint shift from the SST-70. I’m curious to see what the SFT-70 does as well :sunglasses:
Hi Simon, I have two Convoy T2 with Nichia 219C 4000k and I want to buy another two but they are not available with this led. Do you know when they will be available?
Hi, if you are interested in L21A with Osram led, my review is finally done. And my girlfriend translated it to English, hope you like it She is better in this translation stuff.
