i have SST70 LED, i just thought the flux was low .
and i got SFT70 sample ,too
The driver has a built-in temperature control. Now the temperature is low in winter and the flashlight heats up slowly.
Simon, will you be releasing a conversion kit with GT-FC40 and driver for the L6?
conversion kit?uhm
GT LED has 7070 size the same as XHP70.2
and the driver is 30mm diameter ,it’s designed specially for L6 host.
I’m interested in driver only.
If 4A and it could fit M21C-U AND work on single-cell…hell yeah!
22mm driver in M21C-U
and this driver has 30mm diameter
I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
The broad spectrum Green and Orange-Yellow emitters are very interesting as there is still some colour rendering across the whole spectrum.
Unfortunately, it seems that the Red LED driver doesn’t appear to be functioning correctly. Both 100% and 20% appear to have the same output, and it looks like the temperature protection isn’t working as this light runs considerably hotter than the others.
Is the battery fully charged?
i have SST70 LED, i just thought the flux was low . and i got SFT70 sample ,too !https://live.staticflickr.com/65535/50749689213_3a4c53c870_b.jpg! !https://live.staticflickr.com/65535/50750533232_f3c1785eb7_b.jpg!
Good looking beam/tint is more odten better than screaming bluish bin.
Few fluxes less won’t mean a thing in order to keep neutral white beam.
I would go with SST-70 before i buy SST-40 or XHP50.2 3V anytime.
Too bad FC driver won’t be available in 22mm :(
Good that you mentioned E17/21, i’m thinking to install one in new T2 light. It would be great combo and even better in forgoten AAA
SBT90.2 LED SB bin.
25mm and 20mm MCPCB for SBT90.2
Christmas Gifts!
In my opinion, the LED GT 12V 4A 90CRI has a bit of green which is also very good “sudoku 247”:https://sudoku247.co
Rngwn’s items doesn’t have it
Alen: Simon Mao: Alen:Simon
You consider to do an AAA light with E21A 2000K?
Because this CCT does not harm the endocrine system and the sleep cycle,
and is perfect for indoor use.
We lack them.ok ,i will add it in my plan
Well,a small clicky light TIR lens 3/4modes (no strobe)
start 0,1 lm - 4 lm25lm100lm with reversible UI would be nice
with E21A 2000kHow long do you think the AAA flashlight cannot exceed?
It depends,for keychain use smaller is better otherwise 75-80 x 14mm max.
I’d like smooth design
KevinZA1988:Simon, you should try the Luminus SST-70 with a 5A-6A driver in the L6. I installed one in my L6 and the beam is amazing. MUCH better than XHP70.2 and XHP50.2.
That’s awesome! Djozz tested the SST-70 and got 4000 lumen at 6 Amps. His lumens are a bit high, but the SST-70 matches the XHP50.2 in output up to 6 Amps. But then you get the increased throw and hardly any tint shift from the SST-70. I’m curious to see what the SFT-70 does as well :sunglasses:
Hi Simon, I have two Convoy T2 with Nichia 219C 4000k and I want to buy another two but they are not available with this led. Do you know when they will be available?
Hi, if you are interested in L21A with Osram led, my review is finally done. And my girlfriend translated it to English, hope you like it She is better in this translation stuff.
Convoy L21A with Osram KW.CULPM1.TG diode 3 in 1 review. At the end there will be a summary for those who like only particulars, in each topic I will bold the key sentences for those who read a little more, and a long waffling for everyone else. Enjoy! [image] For VERY large photos: click -> on the photo page right click -> "Open image in new tab" Simon, Convoy owner, was very kind and send me this flashlight for this review. You can buy it in official Convoy store: Tab…
stephenk:I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
Yes, this was occuring with NCR18650GA batteries between 3.9V to 4.16V.
It will be available in one week.
Simon Mao: stephenk:I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
pls leave me your address via PM ,i will send one new driver to you
Simon, is there a datasheet for the SFT70 LEDs?
I can’t seem to find anything by search.
Does M21A Osram green giving more lumen that white one?
alex64:Hi Simon, I have two Convoy T2 with Nichia 219C 4000k and I want to buy another two but they are not available with this led. Do you know when they will be available?
Thanks!
Is there any website that allows me to share PDF files?
