Is the battery fully charged?
Good looking beam/tint is more odten better than screaming bluish bin.
Few fluxes less won’t mean a thing in order to keep neutral white beam.
I would go with SST-70 before i buy SST-40 or XHP50.2 3V anytime.
Too bad FC driver won’t be available in 22mm :(
Good that you mentioned E17/21, i’m thinking to install one in new T2 light. It would be great combo and even better in forgoten AAA
SBT90.2 LED SB bin.
25mm and 20mm MCPCB for SBT90.2
Christmas Gifts!
Rngwn’s items doesn’t have it
It depends,for keychain use smaller is better otherwise 75-80 x 14mm max.
I’d like smooth design
KevinZA1988:Simon, you should try the Luminus SST-70 with a 5A-6A driver in the L6. I installed one in my L6 and the beam is amazing. MUCH better than XHP70.2 and XHP50.2.
i have SST70 LED, i just thought the flux was low .
and i got SFT70 sample ,too
That’s awesome! Djozz tested the SST-70 and got 4000 lumen at 6 Amps. His lumens are a bit high, but the SST-70 matches the XHP50.2 in output up to 6 Amps. But then you get the increased throw and hardly any tint shift from the SST-70. I’m curious to see what the SFT-70 does as well :sunglasses:
Hi Simon, I have two Convoy T2 with Nichia 219C 4000k and I want to buy another two but they are not available with this led. Do you know when they will be available?
Hi, if you are interested in L21A with Osram led, my review is finally done. And my girlfriend translated it to English, hope you like it She is better in this translation stuff.
Convoy L21A with Osram KW.CULPM1.TG diode 3 in 1 review. At the end there will be a summary for those who like only particulars, in each topic I will bold the key sentences for those who read a little more, and a long waffling for everyone else. Enjoy! [image] For VERY large photos: click -> on the photo page right click -> "Open image in new tab" Simon, Convoy owner, was very kind and send me this flashlight for this review. You can buy it in official Convoy store: Tab…
stephenk:I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
The broad spectrum Green and Orange-Yellow emitters are very interesting as there is still some colour rendering across the whole spectrum.
Unfortunately, it seems that the Red LED driver doesn’t appear to be functioning correctly. Both 100% and 20% appear to have the same output, and it looks like the temperature protection isn’t working as this light runs considerably hotter than the others.
Yes, this was occuring with NCR18650GA batteries between 3.9V to 4.16V.
It will be available in one week.
Simon Mao: stephenk:I recently received some more Convoy S2+ with coloured Osram CSLNM1 emitters. From left to right - .23 (Red), F1 (Green broad spectrum), .14 (Blue), and .FY (Orange-Yellow broad spectrum).
pls leave me your address via PM ,i will send one new driver to you
Simon, is there a datasheet for the SFT70 LEDs?
I can’t seem to find anything by search.
Does M21A Osram green giving more lumen that white one?
alex64:Hi Simon, I have two Convoy T2 with Nichia 219C 4000k and I want to buy another two but they are not available with this led. Do you know when they will be available?
Thanks!
Is there any website that allows me to share PDF files?
The luminous flux of green light and that of white light cannot be compared with each other.
Simon which tint bin did you get for the GT-FC or did you specify a tint bin when you ordered? For example the C3 tint will be much less green than the D3 tint.
2020/12/22
I compared the flashlight with the L6 XHP70.2. From the naked eye, the brightness of the two is similar. I feel that this sample of mine is a little greenish, which should be due to the lack of red phosphor. Its light spot is relatively uniform, and there is no yellow-green on the edge of the light spot like XHP70.2.
I don’t have a spectrum tester, so I don’t know its true color rendering. If anyone has relevant test equipment and is interested in making a detailed review, please contact me and I will send samples for free.
These 2 made me smiling for days. M21B is perfect host for XHP50.2 and new T2 is simply WOW.
Although description of new T2 say it’s 0.5A on AA and 1.5A on Liion, when running both chemistry on max setting, brightness difference is minimum. At least to me.
I just love it. Perfect size and bright as hell.
Well done Simon!
I see your pic with the turbine engine, Sweet :+1:
Thx CNC!
This is the only reason why I like flashlights, working in dark and visibility is essential. Rainbow tints give me a headache and give the wrong perception of a hydraulic leak (yellow-green corona looks the same as hydro fluid on a titanium material)
