Looking at the actual photo and the measurements of the item is it just me or is the rated CD seem to be very conservative. Based on its measurements I’m expecting north of 1.5m CD but then again my testing equipment is amateur at best for throwers.
Why is there such a huge price jump from the WP1 to the WP2? The difference between the M2S and M1X was only $8.50. Even after the price went up the M1X with M4DMAX coupon still costed less than this. I’m still deciding whether I should go ahead with it. Will the price increase once the groupbuy ends and will there be another groupbuy after that?
Originally the Jetbeam M1X was $22.24 cheaper than the Astrolux WP2 groupbuy price. It did increase after some months but as far as I remember, it was still slightly cheaper. It’s the same light but with an updated UI (better IMO).
i just looked them up, the spec look almost identical, but theres a few differences.
wp2 has magnetic rotary switch.
wp2 is listed to be 100g heavier, which is quite a lot considering its 360 vs 260.
wp2 is listed to run 480lm for 4.4h while m1x run it for 2.7h
if all this is true, then wp2 seems to be running a more efficient driver, the extra weight might be due to the magnetic rotary switch? cuz the dimension is almost the same, with wp2 body being 2mm wider, but i dont think that would account for the 100g
