Fenix ARE C2+ Can't charge LiFePO4 18650???
I have used this charger fine for charging 3.6V Li-ion 18650’s, but I was under the impression it could do Lifepo4 as if you look closely at the display screen it has, Li-ion, Lifepo4 etc. But when I placed some new Soshine 3.2V 18650s in it simply highlights Li-ion. So I guess not?? Any charger with a fast rate & good display that does lifepo4? ie charges to just 3.65V instead of 4.2.
thanks
There must be some button to switch modes if they advertise it as supporting LiFePo4. AFAIK there isn’t a reliable way to tell apart LiFePo4 from 3.6V Li-Ion.
Is this your charger?
https://www.fenixlighting.com/product/are-c2-plus-battery-charger/
It does not mention any support for LiFePo4.
edit: btw for a LiFePo4 charger, consider the Nitecore i2/i4.
My $3 LiitoKala Lii100 also supports LiFePo4.
(if you are not in a hurry, which I am never).
HKJ has a list of chargers that are compatible with LiFePO4s on his *website. Based on his reviews, I picked up a Liitokala Lii-PD4.
Yeah, any charger has no idea if a cell is a LFP cell down to maybe 80% or 30% (both about 3.2V anyway), or a Li-ion cell drained to 3.2V at maybe 15%.
And same here, I use my teeny little LK 1-banger for LFP cells. Just gotta remember to push the button once to switch it.
