Looks a good bit brighter green than my D1, D4, D4S.
I still need a green D1S, and not that chalky surface on the cyan.
Still no 219c option…
NOCTIGON K9.3 DUAL CHANNEL 7400LM 21700 LED FLASHLIGHT
That's a sic amount of choices - made to order...
Wait, what’s the best way to go about spec ing one?
SST 20 5000K centre
Maybe 2700k outer?
Also wonder if both channel can switch on at same time? Would love a W1 white on outer channel too
You could email Hank and ask for a custom build with Osram W1 on Channel 2.
You reckon that would be the best option for throw with the Carlo optics available, I’ve sent him an email to ask his suggestions anyway but it would be good to hear other ideas
Has anyone had any luck getting their KR series tailcap apart? I have a KR4 with a trit button I would like to swap into one of my KR1s (to match colors) but they are both glued tight. Figured I would ask if anyone has tips before I tried. I just use a pair of old tweezers I bent out to grip retaining rings, but I can’t apply a ton of torque that way. I imagine I’ll have to use heat first either way.
I’ve gotten all mine off with needle nose pliers. I get the pliers aligned in the slots, with the tailcap against my palm. I press pretty hard against the tailcap while turning and they all came loose. I didn’t see glue in any of them.
I’ll try this because I haven’t been able to get mine apart either on my KR1 or kr4
Hank, would you sell E21A leds separately?
I cant believe it took me a month to try doing this. FW3x deep carry clip fits great on the d4v2 with a little light modification. the new KR4 deep carry clip attachment ring was just a little too big, plus i had an extra one of these. thought i’d share.
The D4 was always a good pocket clip away from me wanting it. Nice mod! The brass is very pretty.
Thanks!
Is that amber or warm white under the switch?
I have a 9.3 on the way with 9 2000K’s. Def my favorite LED
Hello Hank,
Do you have nighttime pictures of Noctigon K9.3, where I could see, how the beam looks like for E21A at channel 1?
Also, I was already planning to purchase one more D4V2, but could not see Gray color body option - will it be restocked?
Noctigon KR1 other colors coming ?
I couldn’t decide whether to get E21A 2000K or 2700K for the K9.3 so i bought one of each. One with deep red on CH2 and the second on with Osram yellow
