Super review… this emitter is turning heads lately for throw “junkies” (like me: building a C8+ with it next month)
49.37€ |Convoy L21A mit KW CULPM1.TG 8A fahrer ,1190 meter reichweite, 21700...
Smarter Shopping, Better Living! Aliexpress.com
Nice review. Nice light.
Still, seems like turbo mode can be too hot within 10 mins. I wonder how Osram cslnm1.tg will perform in Convoy L21a.
Excellent, it will throw farther but the beam is like a lightsaber, very small hotspot.
Mine does approx 550 kCd on 5A
Thanks for the review.I bought the torch!
Few questions .
- What battery did you use for testing?
-How many CD’s on Turbo?
-I see after 10 minutes on Turbo the temp.was 50C.Very manageable to me.
,Do you think the thermal step down started or is this just an LED that does not generate a lot of heat?
Thanks…dzien dobry
Ooh, I like waffles…
With whipped cream, yummie
And I definitely want one of these… Just Because.
Damn, I got 2 L2s that I rarely if ever use (but they’re soooooooo nice to have, even if bigger’n a P30 or GTmini), but this looks like a nice Überthrower.
Buy it, you wont regret it
Lightbringer: Mocarny:At the end there will be a summary for those who like only particulars, in each topic I will bold the key sentences for those who read a little more, and a long waffling for everyone else.
Yeah, even without whipped cream it’s still great
Few questions .
,Do you think the thermal step down started or is this just an LED that does not generate a lot of heat?Thanks…dzien dobry
I used Samsung 30T, but I always recommend LG M50T, still high drain with great capacity.
I didn’t measure CD’s…
50°C on the surface doesn’t mean it’s 50°C inside. I think it’s much hotter inside actually, because this is a pretty massive flashlight, has thick walls and everything. I think it was not a step down, just LED loosing its efficiency and getting dimmer.
And…dobry wieczór
Nice review. The L21A with CULPM1 is like a custom modded light finally made available for the masses.
Few questions .
Please answer my light questions or I will eat ALL your waffles!
Yokiamy: Lightbringer: Mocarny:At the end there will be a summary for those who like only particulars, in each topic I will bold the key sentences for those who read a little more, and a long waffling for everyone else.
Cochise334ever:Thanks for the review.I bought the torch!
Few questions .
And…dobry wieczór
Dziekuje
Few questions .
It was stated by Simon with 1190m throw. So by calculation. It’s roughly 350kcd. I have only see 2 tests so far. 1 is from Funtastic (his own biuld). Another from Chinese reviewer. Both of them get more than 1300m throw. Will need more reviews and tests from others. Just tested mine on a fresh charged 40T. My Lux readings are always on the high side so probably reading at least 10% too high. I have measured it at 5 m for 19600 Lx which equals 490 kCd (Approx. 1400m) Taking into account …
Cochise334ever: Cochise334ever:Thanks for the review.I bought the torch!
Few questions .
【convoy】SFT40 5000K back in stock (sufficient) - #3885 by Yokiamy
Thanks.Is there Any advantage using a 40T over a 50E when it says the driver puts out 8 amp maximum?
Would I benefit getting 40T as far as output?
Yokiamy: Cochise334ever: Cochise334ever:Thanks for the review.I bought the torch!
Few questions .
I found my answer from this hkj comparator.
The 50E has no advantage at 10 amps until 3.2v where the 40T starts sagging more.I never let.my battery get below 3.5v and have no use for those low numbers.I am getting 40T
Where can I get one? And any codes?
It is official Convoy store, and if you want, you can ask Simon for a 15% discount as a BLF member.
Can somebody lend me 45$?
Simon,
Any codes?
Please read what Mocarny wrote
