-I see after 10 minutes on Turbo the temp.was 50C.Very manageable to me.
,Do you think the thermal step down started or is this just an LED that does not generate a lot of heat?
Damn, I got 2 L2s that I rarely if ever use (but they’re soooooooo nice to have, even if bigger’n a P30 or GTmini), but this looks like a nice Überthrower.
I used Samsung 30T, but I always recommend LG M50T, still high drain with great capacity.
I didn’t measure CD’s…
50°C on the surface doesn’t mean it’s 50°C inside. I think it’s much hotter inside actually, because this is a pretty massive flashlight, has thick walls and everything. I think it was not a step down, just LED loosing its efficiency and getting dimmer.
And…dobry wieczór
The 50E has no advantage at 10 amps until 3.2v where the 40T starts sagging more.I never let.my battery get below 3.5v and have no use for those low numbers.I am getting 40T
Just got light.Impressed that it only took 14 days from ordering to door.
Need HELP! Programming instructions are not in sync with light.I quickly press 20X after light is on.It blinks 5x then pause and continues that over and over.Directions say One blink for corresponding mode.ex.mode 1 is 1 blink.I want mode 6.So i just thought wait until the 5 flashes and tap during the sixth time(mode 6) and I would get mode 6.It just goes to beginning of mode group that it is stuck in.That is group one with 5 levels and 3 blinkies that i do not want.
Any help is appreciated.
EDIT. THANK YOU RUSTY JOE.It needs 30 plus quick presses for config.mode, Not 20 like Alliexpress states!It is now programmed
