[Review] Convoy L21A with Osram KW.CULPM1.TG diode
Thanks for the review.I bought the torch!
Few questions .
- What battery did you use for testing?
-How many CD’s on Turbo?
-I see after 10 minutes on Turbo the temp.was 50C.Very manageable to me.
,Do you think the thermal step down started or is this just an LED that does not generate a lot of heat?
Thanks…dzien dobry
Ooh, I like waffles…
With whipped cream, yummie :stuck_out_tongue:
And I definitely want one of these… Just Because.
Damn, I got 2 L2s that I rarely if ever use (but they’re soooooooo nice to have, even if bigger’n a P30 or GTmini), but this looks like a nice Überthrower.
Buy it, you wont regret it
Yeah, even without whipped cream it’s still great
I used Samsung 30T, but I always recommend LG M50T, still high drain with great capacity.
I didn’t measure CD’s… :frowning:
50°C on the surface doesn’t mean it’s 50°C inside. I think it’s much hotter inside actually, because this is a pretty massive flashlight, has thick walls and everything. I think it was not a step down, just LED loosing its efficiency and getting dimmer.
And…dobry wieczór
Nice review. The L21A with CULPM1 is like a custom modded light finally made available for the masses.
Please answer my light questions or I will eat ALL your waffles!
Dziekuje
Thanks.Is there Any advantage using a 40T over a 50E when it says the driver puts out 8 amp maximum?
Would I benefit getting 40T as far as output?
I found my answer from this hkj comparator.
The 50E has no advantage at 10 amps until 3.2v where the 40T starts sagging more.I never let.my battery get below 3.5v and have no use for those low numbers.I am getting 40T
Where can I get one? And any codes?
It is official Convoy store, and if you want, you can ask Simon for a 15% discount as a BLF member.
Can somebody lend me 45$? :slight_smile:
Simon,
Any codes?
Please read what Mocarny wrote
Just got light.Impressed that it only took 14 days from ordering to door.
Need HELP! Programming instructions are not in sync with light.I quickly press 20X after light is on.It blinks 5x then pause and continues that over and over.Directions say One blink for corresponding mode.ex.mode 1 is 1 blink.I want mode 6.So i just thought wait until the 5 flashes and tap during the sixth time(mode 6) and I would get mode 6.It just goes to beginning of mode group that it is stuck in.That is group one with 5 levels and 3 blinkies that i do not want.
Any help is appreciated.
EDIT. THANK YOU RUSTY JOE.It needs 30 plus quick presses for config.mode, Not 20 like Alliexpress states!It is now programmed :+1: :sunglasses:
I want to get this light! Very affordable for its capability
Welcome to BLF!
I love this light, it throws super duper far.
