charger board is separate ,just driver swap. Ordered boost driver PCBs it should be so f…. cool ;))
Convoy have 21mm driver it can be replaced with this one ;))
Dang, Convoy may be bout the only headlamp/rt. angle head EDC I don't have... I bought like 3 of the Eagle Eye ones when they were so cheap, offered in colors, and with 18650 adapters. I got a blue, black, and silver and only spent the time to mod one :FACEPALM:
Ohh no, I don't use MTN drivers. I reflow my own from OSHPark driver PCB's, usually DEL's but many others as well. I got a hot air system - works great to remove components, either all or singles, even small in tight spots. Forgot what it cost but I got it probably from eBay, pretty cheap, nothing fancy. You can get those all-in-ones with soldering iron and hot air, etc., but I have a good Haiko iron - wouldn't give it up for anything.
JKK90 XHP70.2 version with dual 26650.
Do you have a source we can order the JKK90 SBT90.2 from? Looking for silver short tube if possible.
This would be one interesting little puppy to stick a 15W laser module inside…
Just goggle foxpro predator light firefly
Cylons, watch out!
Twosun now makes flashlights as well:
https://www.aliexpress.com/item/1005001854266385.html
Titanium 18650, 350lm, H-L-strobe.
That's a pretty handsome flashlight.
I found it accidentally. It has a mode ring on the tail. It is a bit like the solution from the Maglite XL200.
Link in the pics.
Whoa! Gotta be careful with that Devil-Level Brightness, though!
Yeah, and be careful with that “magnetic control witch”
That’s to be expected of the FoxHawk FH-666.
I’m not sure if a) this is a clone or b) this is a new light, but:
https://www.aliexpress.com/item/1005002013000704.html
Trustfire has released a headlamp variant of their fresnel lens light:
https://www.aliexpress.com/item/1005001475696937.html
Where do I get the jkk70 or 90?
Can’t find them
Can’t find them
AliExpress has the 90!
EDIT: Page Not Found - Aliexpress.com
EDIT 2 : And the 70 Page Not Found - Aliexpress.com
Link in the pics.
Mag XL200 doesn’t have a mode ring, it uses motion detection, rotating the entire torch.
Here we have what looks like a common 10180 twisty…upsized to 16340:
https://www.aliexpress.com/item/32802945956.html
The perfect flooder headlamp?
https://www.aliexpress.com/item/1005002097096919.html
I actually like it. Looks lightweight and easily upgradeable to CRI97.
Saw this a few weeks ago. If it was 18350 I’d go for it… Realllly want to get a hold of those hybrid Fresnel TIRs
