I think he meant S21A
Yes S21A, sorry for the confusion!
S21A spacers in stock. Plane to plane distance is close to 5.5mm.
Fits 20mm mcpcb correct?
If so I’ll take 3, I’m building a couple quads with a 22mm optic, measurements say I need a 5mm spacer so I’m sure it will work.
any spacers for new convoy s21b?
thanks.
No, I have not made any product for S21b.
Since it has no pill - spacer height tolerance should be more tight. I dont have this host so I can’t say if it can fit any existing spacer or not.
BTW, I can not ship anything to the UK until Royal post will accept international shipments.
thank you, and thanks for the shipping heads up .
Do you have any of these in stock?
thx
Yes, now they are solid (one piece) design.
1 copper and 4 aluminium left.
Sweet I would like the copper will you send PM for payment?
EDIT: do you have a copper P60 pill in stock?
I’m looking for a copper spacer for the M1. I’d like to run a triple or quad LED with a carclo lens. Haven’t decided 100% yet on that, but let me know what you think Kirill.
M1 head is huge. Im not sure it will look proportional with tiny 20mm triole optics.
Ok so you’ve made my decision for me. What would you charge for a quad LED spacer with a carclo lens?
Custom Cu spacer+alu centering ring=$10
Optics is $2.
I’m kind of a newb with this stuff, but would khatod optics be better? I’m looking for the tightest beam and best temp protection possible. I’m a firefighter and I want to build a light that can penetrate smoke. Looking to build this with a warm white (2700-3000k) XP-L HI LED board from MTN.
Dont thin so.
It is hard to achieve tight beam with small multi-led optics.
Actually, I just took another look at MTN and they don’t have any premade quad LED options, only triples. So I’ll have to stick with that. I’m looking at the carclo 10507 lens with a the noctigon 3x mcpcb with XP-L HI LEDs
I think you can add quad pcb and 4 leds to the cart and check toolbox “solder options”.
