That’s really bad. I eyed it when it was on sale, I’m glad i didn’t buy it.
I ordered it and so far, haven't tried charging another battery without protection. I did observe that the green LED comes on at 4V and when the battery was at 4.18V, the charging current was at 0.002A.
Is there a tear down of the Wuben C3?
I didn't let mine charge that long but I can confirm the problem too. The voltage on the DMM is taken directly from the battery after charging with this light.
As ordered in pictures (V, charge rate @ time):
4.38V, 0.116A @ 9:02PM
4.43V, 0.08A @ 10:15PM
if you are removing the battery and adding wires to measure things, that may be throwing the charging off
also if you stop and restart a cycle (esp when it is finished) that may throw it off also
maybe what it really wants is to
a. start with a discharged cell (somewhat)
b. charge from there to 4.13V
if you restart it already at 4.13, that might throw it off
but it should always be checking for 4.20 and never go over that
if you have extra wires, that may uncalibrate the voltage or current readings it is taking during the cycle.
4.52 volts!
Yikes.
First time I tried to charge in flashlight since I got it.
Purchased Nov 27, 2020
It is going back to Amazon.
I’ll try another one as do like the light.
New stock is supposed to be fixed.
Thank you for your time and effort to run a C3 report. I just found this thread on the comment of my WUBEN C3 30% off deals.
Our tech guys has fixed the overchage issues and sqare spot after getting the feedbacks from customers. Stocks now in Amazon
is the new version C3 that do not has overcharge issues and already update the TIRE to has a round spot.
Links to access: https://amzn.to/38EnK7G
A lighting deal is coming in Dec 26th to save 15% off. Additional coupons might show up too.
That’s good to hear. Would be interested to re-test the Wuben C3, but I’m unable to order from Amazon…
“… the TIRE to has a round spot” What does this mean?
The spill with the previous TIR has a square shape... more like 3 corners and a rounded 4th. The spot is round and nice. I should take a picture...
I have a new one inbound for Monday.
Still confused on that comment.
I have a C3 bought about 6 weeks back. Guessing it’s got this over-charge “feature”
I do like the light though (despite the 2600mAh “protected” battery- wass’up with that?). Still a nice throw for it’s small form factor. I’ll just charge via the Zanflare Vs. the internal USB port anyway. Also prolly’ use a Q30 or something a bit more modern battery wise.
I would be too. I posted a picture above so the outer and inner spot IS round and it's just that outer TIR artifact, aka. spill, I think, what some commenters find detracting.
I just pulled mine out and see the “square bottomed” spill as your pic shows… looks like a “flat tire”
— thanks for that effort Nach!
Sorry to make your confused.
The first stocks of C3 has a square spot. But our tech guys has solve this issue by upgrade the TIRE to make the spot round rather than square.
Check Nachtfeuerzeug comment on #19 for more info
OK, I sent an email just now. Are you suggesting I can get a replacement? I own a C5 too (great little light!)
Thanks.
That depends on which verdor you bought from.
This is the shop I charge: https://amzn.to/38EnK7G
Anyoe has bought the first batch C3 from the above link, pls PM me your order number for after- service
Hey great service here! I DID buy from that Amazon shop and am sending you my order # right now!
Thanks Wuben!
C3 is on lighting deals now for 15% off plus 5% off coupon, total 20% off.
Ended in 13 minutes.
Get a new one now to save big
Link: https://amzn.to/38EnK7G
Perhaps TIR was meant?
Olights i1r2 does the same square spill. I thought that would indicate a good alignment of LED and optics.
