I’d be interested if this light features these things:
- Body diameter of 1” to fit most aftermarket gun mounts and consistent diameter throughout body tube. No fins or anything protruding that will hinder mount installation. Most gun mounts are one pieced clamps. Tactical ring is OK just as long as it’s removable.
- Head size of no greater than 40-45mm so the head doesn’t obstruct gun mounting position
3)Remote Pressure switch with constant and momentary on (separate buttons) (as Accessory and/or with mount)
4)Quick and Simple UI that doesn’t have unnecessary modes (i.e. Low or Moonlight)
5)5000k temp or lower to reduce perceived bounce back glare for CQC (doesn’t have to be high cri) - Full potted electronics or at least make it robust a much as possible. If having thicker walls doesn’t allow for 21700 batteries then so be it.
Having points 1-3 will widen your target demographic for dual use as a combat weapon light.
When I want to buy a “tactical light” I expect a tactical light only. I don’t need eco or moonlight modes. If I need eco or moonlight, then I’ll get a small backup flash light with those modes. I’m kinda tired of looking at “tactical” lights from manufacturers that does everything that a regular flashlight would and thus compromising the UI. If I needed extra runtime I will keep spare batteries with me. As all “duty” devices, the batteries shall be topped off every night/downtime and replaced when their capacity is diminished/compromised. I want a dedicated tactical light that will preform as expected/no guesswork and do it well. Definitely NOT a jack of all trades. Hell, Surefire was successful with having one mode lights. They are known for tanky tactical lights that cut out the bulls#!t.
Mechanical Forward Clicky in Tail (primary) and secondary Tail E-Switch (small and doesn’t impede primary). But I’m ok with a secondary body E-switch and that the switch doesn’t turn the light on. The idea to have a light that mimics a full output 1-mode light with everything else as non-priority. This is a characteristic of a true tactical light.
My UI would be this:
Primary tail switch is for constant turn on with full press/click. Half press is momentary on. Output from tail switch is always Turbo/High from off. Full output irregardless of what group you left it in. This is top priority, leave it alone.
The secondary switch is to switch groups. Side switch consists of 2 secondary modes only. Has to be “on” first to change modes so no accidental turn on/unpredictable modes from off
1-click from turbo/high = change to Medium* mode only (This mode should be consistent output throughout runtime). This mode’s purpose is if you absolutely need the runtime with usable light that is bright enough for at least medium distance (50yards)
Hold = change from Turbo/high or Med to Strobe. If anything, this mode could be programmable to have that silly eco mode instead of strobe.
1-click from Med/Strobe = Turbo/high
Hold from Strobe = Return to Medium
Also maybe, programmed to flip the 2 modes (Hold for Med/ Click for Strobe)
/The beauty of this is that you can quickly access turbo (1-click) from any group without cycling through unnecessary groups when on. Also the primary tail switch is will always be predictable with on/off constant or momentary (full output).
so yes you have to turn the light on to switch modes. Remember this a tactical light which full output is predictable and always quickly accessible no matter what.
