Fits 20mm mcpcb correct?
If so I’ll take 3, I’m building a couple quads with a 22mm optic, measurements say I need a 5mm spacer so I’m sure it will work.
any spacers for new convoy s21b?
thanks.
No, I have not made any product for S21b.
Since it has no pill - spacer height tolerance should be more tight. I dont have this host so I can’t say if it can fit any existing spacer or not.
BTW, I can not ship anything to the UK until Royal post will accept international shipments.
thank you, and thanks for the shipping heads up .
Do you have any of these in stock?
thx
Yes, now they are solid (one piece) design.
1 copper and 4 aluminium left.
Sweet I would like the copper will you send PM for payment?
EDIT: do you have a copper P60 pill in stock?
I’m looking for a copper spacer for the M1. I’d like to run a triple or quad LED with a carclo lens. Haven’t decided 100% yet on that, but let me know what you think Kirill.
M1 head is huge. Im not sure it will look proportional with tiny 20mm triole optics.
Ok so you’ve made my decision for me. What would you charge for a quad LED spacer with a carclo lens?
Custom Cu spacer+alu centering ring=$10
Optics is $2.
I’m kind of a newb with this stuff, but would khatod optics be better? I’m looking for the tightest beam and best temp protection possible. I’m a firefighter and I want to build a light that can penetrate smoke. Looking to build this with a warm white (2700-3000k) XP-L HI LED board from MTN.
Dont thin so.
It is hard to achieve tight beam with small multi-led optics.
Actually, I just took another look at MTN and they don’t have any premade quad LED options, only triples. So I’ll have to stick with that. I’m looking at the carclo 10507 lens with a the noctigon 3x mcpcb with XP-L HI LEDs
I think you can add quad pcb and 4 leds to the cart and check toolbox “solder options”.
Ok so I’m back to quad then. Just added 4x XP-L HI LEDs and the standard MTN 4XP mcpcb to my cart at MTN. I also threw a carclo 10621 optic into the cart, but I’m still wondering if you think khatod would provide better temp protection and beam profile? Lastly, I already have an AR lens for the M1 that I’d like to put in front of the optic to protect it from debris. Afterall, firefighting isn’t exactly a profession that treats equipment nicely. Lol
I have not seen anyone who could say why Kathod quad is better than 10621. I suppose this is the reason why I have not heard “khatod quad” for several years.
What do you mean by temp protection? If you need flashlight that can be heated from outside (fire), any plastic lens have similar melting point.
If you are trying to cut through smoke, you definitely don’t want a triple OR quad from khatod, carclo, or anyone. Your best option honestly might be the stock reflector and an Osram CSLNM1.FY (yellow-orange light) [available from Convoy Aliexpress]
You really want a narrow beam, ~4° and the narrowest/least intense spill (field) possible, and to achieve that in a light this size you need a single optic with a domeless emitter with 2mm² or smaller emitting surface area. Even the spill beam, though not intense, will blind you in the foreground and hurt your visibility. A very deep reflector or better a very narrow single TIR or even aspheric light is what you want. If you are ordering from MTN exclusively, he still has the UF-T20 host. Might be a good idea. It’s a glass lens - heavy but flame resistant. Try that XPL HI 2700k in there and compare to the quad setup you build and tell me if I’m wrong.
