Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1569 posts / 0 new
Niko
Last seen: 1 month 1 week ago
How long do you plan to keep it closed?
Constantly closing stores to avoid paying taxes is a very bad attitude towards customers :/
led4power
led4power's picture
Last seen: 58 min 38 sec ago
"To avoid paying taxes"  statement is not true, I'm paying taxes either way, but I can't explain my local bureaucracy and laws in one sentence. Store will be closed probably for another two weeks until new generation of DTP PCBs arrive.
Superstocker
Superstocker's picture
Last seen: 1 day 21 hours ago
Looking forward to the reopening. Best of luck to you and your business!
will34
will34's picture
Last seen: 14 hours 35 min ago
Looking forward to the store resuming operations, I have 2 hosts in need of emitters and drivers.
luminarium iaculator
luminarium iaculator's picture
Last seen: 19 hours 56 min ago
led4power wrote:
“To avoid paying taxes”  statement is not true, I’m paying taxes either way, but I can’t explain my local bureaucracy and laws in one sentence. Store will be closed probably for another two weeks until new generation of DTP PCBs arrive.
And some nice dedicated Osram emitter series drivers?
led4power
led4power's picture
I'm working on new driver generation, but it will take some time.
EasyB
Last seen: 14 hours 42 sec ago
With the LD-x4, when DD mode is enabled in the menu, does DD replace the constant current high mode? Like if I have a 6A driver and am using with a low Vf LED so DD is say 12A, does enabling DD mode mean I don’t have a 6A mode?
contactcr
Last seen: 45 min 43 sec ago
Yes it’s one or the other.
I think weird things would happen if you allow both so I see the point but a shortcut like 2 or 3 clicks for DD might be nice for next gen.
Since it’s possible for DD to be the same as CC high due to battery and LED combo it could have 2 identical modes in a row if it worked that way i guess.
led4power
led4power's picture
EasyB wrote:
With the LD-x4, when DD mode is enabled in the menu, does DD replace the constant current high mode? Like if I have a 6A driver and am using with a low Vf LED so DD is say 12A, does enabling DD mode mean I don't have a 6A mode?
Yes, if you enable DD, high mode becomes real direct drive, there is no current limit anymore.
EasyB
Thanks. I was thinking of a driver for the SBT90.2 in my convoy L2 which ideally would have a 6A ~1hr regulated mode plus DD turbo.
Scallywag
Scallywag's picture
Last seen: 1 day 2 hours ago
Best of luck with the reopening. I’m excited for you (and to see new products).
contactcr
With all these current limited LEDs we are really missing out on these drivers. I hope you are able to get the store figured out before too long as it really feels like prime time for linear drivers. Who knows next year we may be flush with buckboost drivers and some obscure 9V LEDs or something.
led4power
led4power's picture
Linear drivers will stay in flashlight world as long as source of light are LEDs, they are smaller, cheaper and have higher power density compared to switching drivers and that will not change. Also linear drivers can have wider dynamic range of currents without large penalty in efficiency,for ex. it's much less challenging to make linear driver with output adjustable from 0.1mA to 20Amps.
Another advantage is driver quiescent current while driver is active - it can be in xx uA range, which is almost impossible for switching drivers (mA range), so runtime on moonlight/very low modes can be significantly better with linear drivers.
While switching drivers in theory have higher efficiency, in practice (single cell - 3V LED) difference in average efficiency is 5-10% typically - not as high as many here claim. Reason for that is battery voltage drop, so linear drivers maybe start with ~75% efficiency when battery is full, but as battery voltage drops efficiency raises to ~100%, so average efficiency is somewhere in between, depending on which mode you use the most. If flashlight is mostly used in lowest and highest mode, there is almost no difference in efficiency because switching drivers efficiency is not that high either on those modes.
Switching drivers are only option when number of cells in series is not equal to number of LED "dies" in series.
contactcr
And this is why we <3 you. I have a 2 euro coupon on your books so I need a reason to waste like $50. See you soon
World needs Led For Power!
id30209
id30209's picture
Last seen: 2 hours 52 min ago
Neven, any update?
WTB Titanium 4sevens 2xAA tube
led4power
led4power's picture
Still closed,sorry.
dorpmuller
dorpmuller's picture
Last seen: 6 months 1 week ago
led4power wrote:
Still closed,sorry.
Aw, crap... just came over here to get some parts...
"I am the flashlight king! I can light anything!"
square74
Last seen: 11 months 4 days ago
Hello,
is there something new with the shop?
I´m looking for a driver for SBT 90.2 with some (more) amps.
Powered out of 4 or 8 parallel Cells.
Thanks a lot.
led4power
led4power's picture
Hi, it's still closed.
contactcr
Any interesting news to share?
Unloco
Unloco's picture
Last seen: 18 hours 46 min ago
+1
I am waiting for the reopening.
I need some Q8 4040/5050 mcpcb.
led4power
led4power's picture
Store will be opened in first week of 2021.
MascaratumB
MascaratumB's picture
Last seen: 32 min 48 sec ago
Oh yeah, get your wallets ready Cash
Wishing you the best for this new phase of business Wink
led4power
led4power's picture
Thank you!
KevinZA1988
KevinZA1988's picture
Last seen: 3 months 2 days ago
Will there be a premium shipping option to South Africa?
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
led4power
led4power's picture
Registered shipping for many countries is not not available, but I see it is available for South Africa.
TMaxxJJ
Last seen: 2 hours 29 min ago
Looking forward to your reopening! Any new items Neven?
malkoff junkie
malkoff junkie's picture
Last seen: 1 hour 2 min ago
thanks neven….
Malkoff !
led4power
led4power's picture
New design of 3030,3535,4040 16 and 20mm DTP PCBs, Osram CULNM1.TG for now.
