Do you realize that you are asking someone who posted that 9 months ago?
There is a big difference in brightness. 4000K is rated as 11000 lumens, while 5000K and 6500K are rated as 14000 and 15000 lumens respectively.
I just bought the 5000K version, much better tint than the MF01 mini 6500K (SST20x7) I have, no more green shift at low, its more yellow, than green. On the other hand, both flashlights pale in comparison to my Nichia 219c (astrolux s43).
Thank you for the information. I had the opportunity to compare personally. In fact, the 5000K seems a little brighter, but the 4000K CRI makes up for it. I choose 4000K.
The old code (bgmf01s) still works but gives a price of $89 on the BG international site. bg1128 code gives a lower price at $84. May be higher or lower depending on your site.
One of BG’s little tricks. Prices can vary greatly depending on which site you use. To change sites go to account settings.
How different are they? They both use TIR lenses so the beams should be fairly comparable. As a quick and cheap experiment you could apply some frosted clear tape over some of the LEDs to get a little more wider beam.
Hello there.
I want to ask a question a little off-topic.
As I see, a lot of people complain about the factory defect of Astrolux MF01S flashlights, their LEDs fail, drivers burn out, the flaslights starts to work incorrectly, etc. The question is: where to buy components for MF01S: ready MCPCB, drivers, plates, etc? I only see spare parts for the MF01 and there are none for the S version. I’m not a professional in flashlight making or soldering and I can’t fix it myself, just by using a spare part, but there aren’t any. Some time ago, I bought this flashlight on AliExpress, until I got it, but it’s already scary.
Thank you for your recommendation. I will try to contact the store Mateminco on AliExpress, if I have any problems with the flashlight. I hope they will sell me the spare parts, If I didn’t buy a flashlight from their store and I have a renamed version of Astrolux.
Write in Google, for example, “Astrolux MF01S malfunction”, “MF01S burned emitters”. Check this forum topics with it. Some videos on YouTube where people share their problems with MF01/S in the comments. Etc.
I see literally one person with burned emitters and one person with a driver issue and they have sold thousands of these lights. You are being way too afraid for no reason. This light has a stellar reputation.
