Yeah it looks like 2000lm sustained isn’t going to happen.
I had hoped that 7 leds would allow each led to operate in a more efficient zone, reducing total power.
DQG Tiny 26650 XPG2: nice little light, about 900lm sustained (?)
Astrolux MF01 Mini (SST-20): about 325lm sustained
Mateminco MT07 (SST-20) (could’t find a good review of the XPL-Hi): about 258lm sustained
I’m gonna use it outside on bicycle runs in the forest at night (summer and winter).
I would be looking at lights like the Wowtac A4 or A5, Sofirn SP33 or Rofis MR70. (The A5 and Rofis will be all flood “wall of light” though). I would think these lights should be fine with 350~450 lumens continuous, on a moving bike with plenty of air cooling.
I like the side-button interface for my commute, Fenix E35UE shown. I run it on HI continually at 350~400 Lumens and have never had an issue with overheating or anything like that. I have ridden it on pack-dirt XC trails (no hills) and its been fine for that. I have never taken it on mountain trails though. I would need a better mount for that, and more lumens wouldn’t hurt.
The other variable is your max stop distance. That should be used to determine how much throw you will need. This will vary from one person to the next. You always want your light to throw farther than you can stop, so you can identify obstacles with sufficient stopping distance.
The thrunite TC20 is also a contender… but its going to be all flood like the A5 and MR70.
You should probably update the original post to let people know you are specifically looking for a bike light for night mountain-forest rides. Thats a pretty unique requirement, IMHO.
The upcoming Fireflies E12R should be as close as it gets. Specs say it can sustain 2,580 lumens for 10 minutes and 1,200 lumens for and absolutely incredible 2.8 hours if it is true. No other light in this size range comes close but these numbers have not been confirmed as the E12R is not released yet.
The MT07/MF01 Mini have a weird heatsinking issue with the driver, resulting in poor sustained performance at the top of their ramp. I think with the mod that fixes its heatsinking, it should be able to sustain as much or more than the E12R. Get 7 6500k XPL2s in there and I think it should be able to sustain quite a lot of lumens.
That NSX4, with its 4 XHP50.2s and massive amount of cooling fins, that seems like the perfect light for this application though.
No way the MT07/MF01 Mini can sustain more than the E12R even with the copper mod. I have 2 of those. The problem is the 7135 driver. The new FF uses a premium grade Lume buck driver so the E12R will be unmatched at least for the time being. Also 12 LEDs will alow it to run more efficiently than 7 LEDs.
The NSX4 is huge. Not going to be anywhere near pocketable. I love the heat fins though.
The E12R is going to get hot with 6A. My Supfire M6 with 3xXHP50.2 3V is pretty uncomfortable to hold at 6A after awhile, and it’s a much larger light.
We’ll see. Specs say it can maintain 2,580 lumens for 10 minutes before stepping down. Hopefully with driver don’t shed much head given the very high efficiency and also the emitters will be operating in its high efficiency range therefore minimizing heat.
How did you find out that E12R using Lume buck driver? Does this mean loneoceans is making the driver? I do not see where it is listed that the new flashlight is a Lume driver on the website, unless you confirmed with FF or loneoceans? Maybe we can ask what the spec is.
At first I thought the E12R was using the same optic as the ROT66.2, but looking at it again, it looks as though the optics are crammed closer together. Looks to be same diameter as ROT66.2’s head, just larger, throwier optics? It is an interesting light, indeed. XPL2s are so damn efficient, with all 12 being able to run at 1200 lumens for 3 hours.
NSX4 doesn’t seem too much larger than the E12R. It is a little longer, but it never gets wider than 44mm. Seems perfect for jacket pocket carry, even though it is an inch longer.
