Just got a Nitecore TINI 2, swapped out the stock emitters for 2x 4000k LH351D’s. Looks excellent, very happy with it now.
FW3A w/ 1x Osram Red Flat (as secondary) and 2x Samsung LH351D (as primary) flashed with Anduril 2
Not sure what to think of this one. I don’t like the Mountain PCB with the XQ-E pads for secondary because it makes a hideous looking rorschach test beam (I think it’s a bat). This is definitely better. The Osram beam is pretty even, albeit a little square up close. This is with 10511. The white LH351D is fine with only two, looks round except for the usual spikey edges all triples have. Also wanted to give Anduril 2 a try since I had to reflash this thing anyways, two birds one stone. May try XP-E2 far red to see what a domed beam looks like if I ever take it apart again.
Hideous test setup. 18650 battery holder, separate e switch, alligator clips, etc.
1x7135 trace cut and negative secondary wire (in orange):
MCPCB mods. 2x traces cut and LEDs reversed to create a second negative pad for Osram and common positive for everything else. (keep in mind this will be different for ALL other boards besides LED4Power)
Always clean up
Wired
Hex file with new ramp table and latest (as of today) Anduril 2: google drive link
special thanks to staticx57(?)
Nice work on this one!
Outstanding!
Q: How can you store 23 lights on your desk without them occasionally becoming dominos?
A: 3D printed holder of course.
I don’t own a 3D printer (I sent my file to Treatstock) and i’ve never designed any print before this so i’m sure this could be done way better but it was fun to learn. The AAA size lights came out a bit tight but all the rest fit perfect. I added clip “grooves” on some to support deep carry clips or face up/down. They are in deep enough I can pick up the whole thing 45 degrees and nothing comes out. I chose “translucent red” just to see how well light could shine through it in case I wanted to make a fancy version 2 or see if I left a light on. It’s not really translucent at all it just looks like flaked red which is fine.
Oh also, any ideas for a version 2?
It could have been flat with just sunken holes but I feel like it would look more like a block of wood that way? idk
I also considered trying to countersink a few holes to allow forward clickies to stand but I decided that could be done with a drill after plus I have very few small fwd clickies.
I beveled the outside of the holes but I couldn’t figure out how to easily bevel the inside diameter. If I didn’t go with the raised design I would have for sure done this.
It may be a bit dense/crowded?
It might be cool to have them be smaller but modular and have puzzle piece type attachments for separate trays 18650/21700, AA/16340, AAA, etc.
That gives me an idea for how to do this really cheap - problem is, I don’t have large enough drill bits, so it gets expensive again…
FYI, this was $24.63 shipped and that’s with this weird color and me probably creating the most complex/not-optimized print.
Working with wood you would have to like chisel out the clip slots or forego that functionality. IMO having them fit tight in the holes and creating clip slots was worth it.
@contactcr Very nice! What design software did you use?
My “mod” today is inspired from my entry in this year’s Old Lumens contest. While that touch lamp is cool, it’s really not feasible for my kids to use and it’s not very reproducible.
So I designed a new housing with Fusion360 and printed it on my 3D printer using PETG (after a couple revisions to get all the dimensions just right). I designed a simple circuit board in Eagle and sent it off to Oshpark using their After Dark service. I’m also using an off-the-shelf TP4056 charging board with protection features.
Put that together and I’ve got a nice compact very simple on/off touch lamp with built in charging.
I used TinkerCAD which I guess is AutoDesk’s free online tool.
I’ll share it when I modify the AAA slots in case someone else wants the same design or wants to modify it themselves.
Cool. Yeah, TinkerCAD is a great place to start.
Very Nice work ‘contactcr’. I love watching and learning from you guys
Wish I understood the details of your work on the driver. I like the flashlight stand
Is that your Home Shop ? If so, that is Sweet :heart_eyes:
Nice light ‘gchart’ :+1:
Could you tell me what 3D Printer you have ?
Also, I gave up on Fusion 360 after Autodesk killed it for cnc use.
I have FreeCad installed but I have not played with it yet.
Do you have any suggestions for a free cad software for a 3D printer ?
Thanks CNCman! Besides the basic TinkerCAD, the only CAD software I’ve used is Fusion360. It’s too bad they’re locking out some features. Thankfully it still does everything I need in the Free version.
I’m not really familiar with it’s usage for CNC. I know they originally announced the removal of several features, but then on Sept 25th they back tracked on that and decided to keep STEP export. I know that’s one of the CNC-related features, right?
This is my last mod. Mf04 with driver from mf04s and Gt-fc40 led with 4000k 90cri.
There is my aux board too.
Total overkill with FC40!
Yes, the removal of STEP file export was a shot over the bow warning that it will be permanently removed in the future. So after a year of watching Youtube videos and practicing drawing models and i was just starting programming 3D models, Autodesk did what i was afraid they might do and kill it. The STEP export will be removed in the future, so i deleted it and loaded Freecad.
Very nice ‘WallKiller’ Love those blue lights !! :heart_eyes:
Do you have any pics on the blue lights ?
Hmmm, i don’t make so much pictures but you can find something on my FB page:
I’m new in this stuff, I like projecting pcb’s and flashlights so I combined it to modder hobby.
