I Buy FW3A 31 Ago 2019
If I try to click 13 times nothing happen
For reset I have to unscrew the tail and press button before screwback.
I don’t want to unscrew tail so I do the reset with the head
To make sure the reset has been done I try Ramp mode but there are 4 levels and not 7…so nothing as been reset
There’s no reset for your light.
I do the reset one time only few month ago… are you sure?
Power is connected before the signal tube for the switch, so holding the switch doesn’t work. You have to do 13H. If it doesn’t work, the light does not have factory reset. Lumintop was very late with using a newer firmware.
From off, try 13 fast clicks and hold the last one. The led should do something.
Or try 13 fast clicks and hold on the 12th or 14th one.
I don’t have the later model, so I’m not sure.
From Toykeeper:
From a regular “off” state, click 13 times and hold the last click for a few seconds. Then keep holding the button for 3 seconds. The light should flash an increasingly bright warning, during which time the user can let go to abort without any changes. Then after 3 seconds, it gives a bright flash and fades back to nothing. This indicates the reset has completed.
Instead of doing a reset, you can change the number of steps.
Make sure you are in stepped ramping mode, not smooth.
Turn light On.
Do 4 fast clicks
Let the light do the first flutter, then let it do the second flutter.
When it is doing the third flutter, click 7 times. Then let it finish.
Now you should have 7 steps.
Turn light On.
Do 4 fast clicksLet the light do the first flutter, then let it do the second flutter.
When it is doing the third flutter, click 7 times. Then let it finish.Now you should have 7 steps.
I know I know, thank you :+1:
I would like to do a reset is for the temperature sensor
I don’t remember where, but I read in forum that I have to press the switch for 3 seconds after screw tailcup.
There is a mode for understand if my fw3a is compatible with reset or not?
The FW3A was NEVER meant to be reset by disconnecting power. It HAS to be done through the 13H clicks (assuming it has the reset software option).
I have a video on how to reset the thermals.
Make sure the light is internally at room temp.
Light Veteran:I would like to do a reset is for the temperature sensor
Video is not available
Light Veteran:I Buy FW3A 31 Ago 2019
To make sure the reset has been done I try Ramp mode but there are 4 levels and not 7…so nothing as been resetThere’s no reset for your light.
The reset is available from what date?
Hard to say for the FW3A because Lumintop started very, very late with using a newer firmware. Not sure if they even use a version with reset yet.
Light Veteran:The reset is available from what date?
So we have all FW3A not resettable?
SammysHP: Light Veteran:The reset is available from what date?
It’s unknown. Maybe newer ones have it, but older ones are still being sold from their inventory. You would need to do the 13H to find out if yours has it or not.
Light Veteran: SammysHP: Light Veteran:The reset is available from what date?
I try but nothing happen… 12 click, 13 click or maybe 14 click… just for fun :person_facepalming:
JasonWW: Light Veteran: SammysHP: Light Veteran:The reset is available from what date?
Why the sad face? None of my lights have the reset and it is no big deal. They work just fine.
Light Veteran: JasonWW: Light Veteran: SammysHP: Light Veteran:The reset is available from what date?
Yes men, all of my light are old… only the Astrolux FT03 has reset
