You could do a mix with 3x2000K and a higher CCT. For example with 4500K -I get 2269K duv 0.0060 (calculated from independent measurements at 1.25A per LED). In my opinion a negative duv makes warm temperatures look so much better.
Edit : used the wrong measurements, 2506K duv –0.0094 is the right result (makes more sense), so a lower CCT than 4500K should be used, 3500 (~2350K duv –0.0040) or 2700K (~2180K duv –0.0016).
That’s certainly an option. I might do this if I decide to pick up another one.
I have an FW3A that I mixed 2700K, 3500K and 5000K LH351D and it resulted in a nice 3600K combined CCT and a beautiful tint. I want to do something similar at some point with a KR4. I just hate messing with the aux board and those tiny wires.
I’d also be up for another run of 2200K. They had great tint, and the difference between 2000K was noticeable. I’d probably buy another K9.3 and KR-4 with those emitters. I also reset the W/B, if you don’t mind to 2200K to show off some of that rosy tint of the 2200K E21A. I believe the 2000K from Hank’s second batch was on/slightly above the BBL while the 2200K was BBL.
That’s the version I would like to get. I really like the copper and am tempted, but it comes in at 0.723 Lbs with a 30Q installed. Maybe that’s a reason to get it. But I’d still like to see the TiCu version.
I’m seriously thinking getting kr1 cu in sst40 5000k. Never thought I’d want the kr1 with that emitter, but the more I’ve thought about it today the more I realize it would be an ideal all purpose light. Enough lumens, enough throw, good enough for me cct (I like the sst40 5000k). Really seems like the best option for me, considering I have the w2 aluminum kr1 already and I don’t buy multiples of the same light with the same emitter. Really wish the kr1 came with xhp35 option. That’d be perfect, xhp35 in 4000k. I considered the xpl hi 4000k, but the trade off for the better cct doesn’t seem worth it compared to the osram (50% more throw, same lumen) and sst40 (70% more lumen, 25% less throw)…
also, is the xpl hi 4000k high cri or no?
I’m for one excited af for the all cu version. Heavy is fine with me. And I’ll buff it on the buffing wheel because I like the new look. Sold two flashlights today so I could buy it. Just waiting on Hank to respond on how to make note for deep carry clip, and I need an optic for d4sv2
As well.
