When I clean threads on a lamp it is always dark grey smudged.
There is no solder, lead or tin, involved in your case. It’s just aluminum.
Sari33:What is the best solder league to put on the positive driver contact to protect it from scratch?
In the past I used Sn-Pb 60/40 but after a little use it blackened and had to be cleaned, I thought it was caused by the presence of leadFrom djozz:
How to add brass foil on the contacts
Q:
[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED - #1957 by djozzYou can also get gold contacts.
Page Not Found - Aliexpress.com
pure 24K is probably too soft.plated Contacts should work better
14.91€ |100 teile/los Poding Münze Zelle Negative Batterie Kontakte SMT/SMD 0,15mm Edelstahl Gold Platte Batterie Kontaktieren BC 1126 G|Instrumententeile & Zubehör| - AliExpressor this: Gold plated copper
22.64€ 15% OFF|TANGDA rechtecke platz Elektronische test kupfer blatt Gold überzogene kupfer messing Kontaktieren blatt SMD terminal Anschlüsse SMT EIN.|connector terminal|connectors electronicconnector smd - AliExpress
Nice find but I already have some thin nickel plated brass sticks.
my question was about the marks on positive driver pad caused by battery pole
I wanted fix it with a small solder blow from an alloy that does not form oxide and more hard than SN/PB.
Sounds like you want precious metals
Trying to order from Sofirn but they ask for a lot. Can’t just use PayPal. Just gave up.
joechina: Sari33:What is the best solder league to put on the positive driver contact to protect it from scratch?
Q:
22.64€ 15% OFF|TANGDA rechtecke platz Elektronische test kupfer blatt Gold überzogene kupfer messing Kontaktieren blatt SMD terminal Anschlüsse SMT EIN.|connector terminal|connectors electronicconnector smd - AliExpressNice find but I already have some thin nickel plated brass sticks.
you could sweat solder a small piece of sheet silver on there instead, it`s a better material than gold (or anything else) even it`s oxide conducts as well! it`s also a soft metal. I replace all sorts of flashlight parts with pure silver, it`s worth getting some in (for everyone into repair and modding).
Thx for suggestion
Will try Ag sheet if I find it
arow55:Just gave up.
Yea by the time they charge shipping at Sofirn same price. I was thinking folks were getting the c01 for $4
yes, but you have to buy 6 to get the free shipping…
arow55:I was thinking folks were getting the c01 for $4
And how many of the co1s?
arow55:how many of the co1s?
Tried 4 and got free shipping. Very confusing sight but hopefully smooth sailing from here.
Yeah if you notice up at the top of the Sofirn page, it says free shipping on orders over $21.
Not a bad deal….
Not a bad deal….
Can’t find that notice but that’s what I needed to know.
Backpacker Light:Yeah if you notice up at the top of the Sofirn page, it says free shipping on orders over $21.
Not a bad deal….Can’t find that notice but that’s what I needed to know.
It’s in the blue band at the top of the Sofirn page.
arow55: Backpacker Light:Yeah if you notice up at the top of the Sofirn page, it says free shipping on orders over $21.
Looked again nope but now I know.
Fo run stock Led at ~40 mA max.
Jumper with solder blow the 220 resistor without remove it
or I have to change resistor with lower value like 10Ω ?
Is the silver version anodized silver or the unanodized version? Also how long are shipments taking to US lately.
There’s no silver C01. The silver C01S is not anodized.
