FREEME ✌ ASTROLUX EA01 SST40 (2300lm)/ XHP50.2 (3500lm) TIR 26650/ 26350 Flashlight Group Buy - ALIVE!
yes that’s strange because the FT03 runs on a 21700 battery and only has one emitter
Hadn’t notice that…
I also just received the EA01 several hours ago. (I got 1 unit EA01 with SST40 5000k and another EA01 with XHP50.2 5700k).
I’m not able to directly measure lumens, but I checked the tailcap current when using an iJoy 4200mAh 26650 (charged to around 4.1v, so nearly full charged)
On the EA01 SST40 5000k, I measured 7.8 Amps tailcap current (UT210E), although this may still not be max power, since it’s not yet fully-charged battery.
However, when I set the EA01 with SST40 to Turbo, I notice the beam turns a bit bluish (from the slightly pinkish color when at Ramp Ceiling level). So this seems to mean the LED is driven a bit too high?
On the EA01 with XHP50.2 set to Turbo, the light works OK.
I’m guessing it’s a FET+1, since on battery-insert, the measured current is around 0.35A (NoPWM),
when I set to Stepped Mode, there is ‘fast PWM’ on all the default 7 brightness levels of Stepped Ramping
Again, also NoPWM when on Turbo mode. So this seems to match behavior of FET+1… (I’m not that well-versed in electronics, but I try to measure tailcap currents of flashlights when I’m first testing each of them)
Thank you Bombay! I am very glad to see it is quad sst40 and xhp50.
Freeme- are there any coupon codes for the MT04 on BG?
Thank you!
Good beam
Interested, can I get a code for the SST40?
Interested
Which version is this?? Awesome beam!
SST40 5000K
will the imalent 265P45 fit inside the EA01
the length is 67,4 mm
best
andy
The Keeppower 26650 4200mAh, 68.7mm, fits fine :slight_smile:
very nice, thanks alot
best
+1
Will it Lego?
Interested in xhp50.2 version
the code BGEA01 doesnt work anymore
Banggood tells me its expired.
best
andy
iam also interested for the 4x xhp50 version…:slight_smile:
That’s pretty cool. Don’t think a 26350 would cope too well with 4xXHP50.3 on turbo though
My Astrolux EA01 (SST40) turns bluish on High brightness levels.
I'm not using a particularly high-drain battery, just a nearly-full charged 26650.
(I measured the tailcap current using a Shockli 5500mAh 26650 battery with my UT210E meter -- around 8.2 Amps on max brightness)
Anyone has this issue?
looks like the EA01's 26350 tube will "lego with" the FT02S body tube..
anyone knows if it will also fit in FT03?
Just an information I got from manufacturer: The SST20 quad version is supposedly no longer being made and wont be restocked :frowning:
