The EA01 SST40 turning bluish on high brightness occurs, while the flashlight is cooled (haven’t used it for a whole day), then insert battery and just testing it…
I’d like to confirm if this issue is only on my sample (which means, I’ll need to report to Banggood about a flashlight with issue), or it occurs for many samples of this EA01.
(I also got the EA01 XHP50.2, which doesn’t have this issue).
One other issue I encountered with the EA01 (in case someone else can confirm), since I got 1pc blue body color and 1pc gray body color.
The EA01 blue body color’s body tube will fit Shockli/Vapcell 5500mAh 26650 (just a very snug fit), but the EA01 grey body color’s body tube has a bit of trouble fitting the Shockli/Vapcell 5500mAh 26650 battery — I have to insert the Vapcell/Shockli 26650 from the head portion of the body tube, and even then, it sort of tears into the battery wrap due to the very tight fit. It doesn’t fit when I insert the 26650 from the tail portion (it probably will fit, but may tear the battery wrapper which I didn’t force into).
A just slightly slimmer 26650 battery (eg. iJoy 4200mAh 26650) will slide in nicely though, both the EA01 grey and EA01 blue.
It means the emitter is overheating and there’s something wrong with the thermal transfer between the emitter and the body. You can try and fiddle with that on your own but I’d just use the warranty.
