Single AA light with only low and high and no memory
53 posts / 0 new
jon_slider
jon_slider's picture
Last seen: 15 min 39 sec ago
Icarus wrote:
I really don’t like the design of the Olight i5T
I agree Smile
but it has two modes.. lol
the image of the flying Greeks,
came up when I searched your handle,
I think its cool too
it is titled
The Flight of Icarus Smile
Icarus
Icarus's picture
Last seen: 1 week 1 day ago
jon_slider wrote:
Icarus wrote:
I really don't like the design of the Olight i5T
I agree Smile but it has two modes.. lol the image of the flying Greeks, came up when I searched your handle, I think its cool too it is titled "The Flight of Icarus":https://en.wikipedia.org/wiki/Icarus :-)
I know this story. There's a reason why I choose this nickname. Wink
jon_slider
I love greek mythology… thanks for the interesting google
I look forward to hearing you found a light that makes you happy, soon Smile
Icarus
Icarus's picture
I would like to thank everyone who contributed to this thread. Big  to all of you!
At this moment I'm leaning towards the Streamlight ProTac 1L 1AA. Most important this light can be setup with low - high, has no memory and can run on CR123, 14500 and AA (alkaline & lithium) cells. Also important I like the design, Streamlight is well known for making reliable and good quality lights and the ProTac 1L 1AA is available in Europe.
My existing Convoy T2 will get a LED4Power driver. This is by far my most favourite (highly custom configurable) lineair driver which I'm currently using in all my recently modded 1 cell lithium flashlights.
This being said I will also try to build an Oshpark HQ 17mm boost driver for the Convoy T2 host I ordered today. Thanks to Bourbon Guy for pointing me to this possibility and all the hard work done by HarleyQuin. Thanks guys!
Bourbon Guy
Last seen: 1 week 8 hours ago
Which driver are you planning to build? I have a couple of working 17B’s but failed to build a working 17D. I should sit down with a multimeter and see where the problem is.
Either way I’m glad someone else is attempting them.
Icarus
Icarus's picture
Bourbon Guy wrote:
Which driver are you planning to build? I have a couple of working 17B's but failed to build a working 17D. I should sit down with a multimeter and see where the problem is. Either way I'm glad someone else is attempting them.
PM sent. Smile
Chronovore
Last seen: 4 hours 56 min ago
Katherine Alicia wrote:
Sofirn really need to make the C01S in AA size, that would be perfect!
I would be interested in this. Some of my favorite lights are the three-mode L10 and L11C. Sadly, they are discontinued. Crying
kramer5150
kramer5150's picture
Are you sure the ProTac 1L-AA will work with a 14500 (4.2 volt) cell?
Thanks!
Icarus
Icarus's picture
kramer5150 wrote:
Are you sure the ProTac 1L-AA will work with a 14500 (4.2 volt) cell? Thanks!
According to someone who used his ProTac 1L-AA with a 14500 cell the light seems still to work just fine after about 50 charges. However, configured to Low-High it seems there is only high when using a 14500 cell.
pc_light
pc_light's picture
Last seen: 2 hours 20 min ago
The 1L-AA does have 2-levels using a 14500 when configured as Lo-Hi. It’s just that they aren’t as visually distinctive as compared to something like the OL i5t’s 2-levels. Also, one must half-press relatively quickly (short OFF time) to switch between from one level to the other.
edit
Actually I should have said “(short ON time)”. To get to High from Off, simply double click quickly fom Off.
However, if the first click to Low is On for more than about 1 second, getting to High from that point requires a double click to cycle through Low-then-High.
Seeking the light.
kramer5150
OK thanks!!
amtaham
amtaham's picture
Last seen: 2 days 10 hours ago
Just passing by a new Skilhunt E2A, an AA/ 14500 with 3-modes, Low – Med – High. I do not think there is a flashlight with only 2-modes CMIIW
“Come again, please, come again, Whoever you are. Religious, infidel, heretic or pagan. Even if you promised a hundred times, And, a hundred times you broke your promise, This door is not the door of hopelessness and frustration. This door is open for everybody. Come, come as you are.” ~ Mawlana Jalaludin Rumi
MascaratumB
MascaratumB's picture
Last seen: 11 min 48 sec ago
The Skilhunt doesn’t fit OP’s requirements.
And there is/are flashlights with only 2 modes. The one I presented (Olight i5T EOS) is one of those.
toddcshoe
toddcshoe's picture
Last seen: 1 day 9 hours ago
Ran across the Nextorch C1. Single AA two mode light. I’ve never had a Nextorch so I can’t speak to it’s quality.
"Everywhere I go, there I am"
samyy
Last seen: 2 weeks 6 days ago
Another candidate – Trustfire T2 …. with Cree XPL, 2 levels, no memory, works with AA and 14500.
Icarus
Icarus's picture
samyy wrote:
Another candidate - "Trustfire T2":https://es.aliexpress.com/item/4000492464729.html?spm=a219c.12010612.814... .... with Cree XPL, 2 levels, no memory, works with AA and 14500.
Problem still is that in the 2 level mode the light comes on in high.
In.love.with.li...
Last seen: 8 months 2 days ago
I also don't like the Olights  i5T EOS..
Does someone have a similar flashlight to recommend but with a better design?
Similar in specs that is Smile
lumenzilla
lumenzilla's picture
Last seen: 1 min 26 sec ago
I have an Armytek A1 Partner, single AA and only has two modes.
Unfortunately, I have no idea if you can still find it on the market or not.
The latest model they currently have is the one with 8 modes Facepalm
Icarus
Icarus's picture
lumenzilla wrote:
I have an "Armytek A1 Partner":https://budgetlightforum.com/node/22952, single AA and only has two modes. Unfortunately, I have no idea if you can still find it on the market or not. The "latest model":https://www.armytek.com/flashlights/models/partner/armytek-partner-a1-pr... they currently have is the one with 8 modes :FACEPALM:
I can't imagine why one would need 8 modes.
amtaham
amtaham's picture
Thank you for the info
MascaratumB wrote:
The Skilhunt doesn’t fit OP’s requirements. And there is/are flashlights with only 2 modes. The one I presented (Olight i5T EOS) is one of those.
MascaratumB
Yesterday I was looking into Jaxman (AliExpress) store as I wanted to order a new Jaxman E3. While reading the specs, I noticed this
https://www.aliexpress.com/item/32610831028.html
Quote:
“Now we have make a 3modes version driver for the E3 flashlights.And if you need 2 modes version, we also can provide for our buyers.The middle mode is realized by PWM. The estimate runtime of every mode is(tested with a Ni MH 1.2V 2100mAH battery):”
So, jaxman can make a driver with 2 levels…I am not sure if the levels will suit your needs.
I can tell, though, that the E3 is an incredibly strong flashlight as host
Wink
Icarus
Icarus's picture
MascaratumB wrote:
Yesterday I was looking into Jaxman (AliExpress) store as I wanted to order a new Jaxman E3. While reading the specs, I noticed this https://www.aliexpress.com/item/32610831028.html
Quote:
"Now we have make a 3modes version driver for the E3 flashlights.And if you need 2 modes version, we also can provide for our buyers.The middle mode is realized by PWM. The estimate runtime of every mode is(tested with a Ni MH 1.2V 2100mAH battery):"
So, jaxman can make a driver with 2 levels...I am not sure if the levels will suit your needs. I can tell, though, that the E3 is an incredibly strong flashlight as host ;)
Thanks for the info. I noticed this too and have been talking to Jaxman. Communication is slow and seems difficult though.
