It means the emitter is overheating and there’s something wrong with the thermal transfer between the emitter and the body. You can try and fiddle with that on your own but I’d just use the warranty.
I ordered both the xhp 50 and sst40 versions. In my sst40 I noticed a tint shift also at the highest setting. The tint shift is less when using Keeppower 26650 5200mah vs Samsung 40T.
I got the XHP50.2 version and in testing with freshly charged batteries I am getting way more than 3500 lumens. I am estimating 5500 at turn on. I am hoping others will do some more accurate testing and let us know what they get.
My measurement is more on conservative side if my follows have noticed. Published values that are achievable by most owners with a good pair of freshly charged cell(s). I will provide another set of result when my new set of higher performance batteries arrive in 3-4 weeks time.
However, from my previous comparison with other reviewers test results, my values are usually differ by 15% max for under 10,000lm class light?
Owners feel free to share your personal test results with our readers. Do specify:
Both my ea01 were delivered today! They are really nicely made, fit the 40t battery well, and have interesting beam shape/patterns with this optic. Can’t wait for night fall! This is the sst40 5000k (gray) and xhp50 5700k (blue).
Depending on the mcpcb size / layout (I’ve never had a TIR optic light and don’t know what to expect when I take the bezel off) I may drop a CULPM1 into one of these this coming weekend. I’ll post before and after beamshots if that ends up happening.
