This is good info. Part of me is slightly “concerned” of the lower lumen rating of the e21’s, but I mean it still is like 1200 lumens right? That is enough for edc really
Even 400-500 lm is enough for EDC (in most cases). I have Skilhunt H03 fitted with 4000K and 5000K E21A (4 emitters per headlamp), and from day one, those are the most carried/used flashlights of mine.
I am not sure though, how much lumens do the modified Skilhunt H03 and/or the D4V2 output.
If you need a “power EDC”, then I might suggest Astrolux MF01S Mini (7× SST-20 4000K with 26650 battery) - or I’d wait for restock of the D4SV2 (4× SST-20 4000K, but with more throwy optics - a favorite from LEDiL).
I actually switched all the GU10 bulbs in my office to 2000K today. I’m addicted to this color temp
I too used to chase lumens. I have several lights over 10,000 in 6500K and the 100,000 lumen MS18. My very first non 6500 light was the ~3300K D18 and I’ll probably never get a 6500 again.
Adam & photon - thank you. I really appreciate the information and suggestions. I think I’m going to try the 3500k kr4. I just put a sst20 2700k in my amutorch sd3 little mini C8 style thrower and it is AWESOME. I Put a 4000k sst20 in my Astrolux C8 a couple days back and now I notice two th8ngs- the 2700k throws further and looks brighter, I don’t know if it has to do with the drivers of each light BC the reflectors are the same size. Secondly, the 2700k makes the 4000k look like a 6500k light which I def8tnely wasn’t expecting. I’d love to go 2000k for the kr4, but honestly I’m worried i will literally ruin all of my other lights appeal… I think that is the biggest reason 8 haven’t made the jump to an e21 light yet, I don’t want to fall out of love with all of my lights ive accrued in the last year… anyone have that problem?
Just went for a night walk with two of my 9.3’s. Have to say, the E21A 2700K / Osram yellow is not very impressive. Not sure what I’ll use the dim yellow Osram for and the and 2700 is too warm for my taste
On the other hand, the light with the XP-L HI V2 5D 4.000K on channel 1 is awesome. First time I’ve seen this emitter and I really see why people love it so much. Tons of power! The red on CH2 is good too although as others have mentioned, not quite as impressive outside as it is indoors
This is GOOD info for me, im sorry to hear about the little bit of a let down, but thank you for sharing. helps the rest of us. If you could maybe post a beam shot of any of them that’d be cool too :+1:
Awesome! I should also mention that the The “indoor K9.3” I got is awesome – just what I was hoping for. Black with red switch, 2000K E21A and red on CH2. Maybe I’ll gift the 2700/Osram yellow and buy a replacement (:
I got them to help preserve night vision at very low levels since I don’t care much for monochromatic LEDs. Might be nice for reducing glare in fog too.
Honestly, I wasn’t really sure what else to put in there because with E21A on Ch1, the SST options wouldn’t really be all that useful and I don’t have any use for the green either. So that leaves the FY.
Would have been cool to see slightly larger diameter lenses for the three Ch2 emitters and an option for NM1.TG, but that would have increased the head diameter. I think it’s fine the way it is now and Ch2 is just a nice gimmick to fill in some empty space in the optic.
I just ordered the all copper d4v2 with the E21A nichia 3500k emitters, I havent seen the literature on the wesite but I am assuming these are high cri too like the sst20 emitters? Just wanted to be sure. Thanks!
Can’t wait to hear your inpressions. I have the 2000 and 2700 and I’ve been thinking of grabbing the light you have coming. Do you have any other warm emitters for comparisons?
Having the exact same for couple of weeks . Mine was shipped with the 10622 optics since the 10623 was out . Yours will probably be shipped with the 10623 . I have the 10623 installed on all my other 5 d4v2, but on this one the 10622 is good . On your next order, you should get it to try.
Haven’t seen any pics of a switch with red LEDs yet….
I’ve finally found absolute perfection in a bedside light. Red switch LEDs match the red aux LEDs perfectly (thought it might look pink through the rubber switch). The red aux LEDs and switch on dim don’t interrupt my sleep, yet its easy to find and turn on in the dark. The SST20 2700k is easy on the eyes early in morning, and the bedroom looks like it is illuminated by an actual candle when on candlelight mode.
