Pull out the pill , with LED driver , and a P60 pill might drop in , I have several lights Ive done this with
But the P60 module will have a big gap between the module and the body... yes or not? The original LED+driver is screw or press fit?
Yes they can ..
The one I had has a ring that screw in to hold the reflector in place ..
This same ring can hold the p60 pill in place , in the head , ... Might be a bit of pot luck ..
But I find if the reflector is large enough , then a P60 pill will go in OK ..
Do we know the dimensions ? Of this light ..
120mm x 30mm only that (and it can really fit 1x18650 OR 3xAAA? too thin to fit AAA)
I suspect it's a bad copy & paste job or the battery holder would have been pictured. I could be wrong, of course, but that's what usually happens.
I also wouldn't be surprised if the "free shipping" bit was a mistake. The same seller has some other lights that, while mostly competitively priced, don't include free shipping (Skyray for $11 + $9 to the US) and the prices on the lights I checked seem pretty much on par with the competition if you figure in shipping.
Judging by the photo it looks very cheaply made and spray painted.
I just received my shipping notification. No tracking number, naturally, so I guess it'll be here sometime within 1-8 weeks.
^i can wait. lol
The one I got is not great .. dino direct had them for 3 bucks .. they were listed as 300 lumen lights ,, yeah right and I'm the pope
http://www.dinodirect.com/LED-Flashlight-1W-Black.html
Actually i just jammed a 18650 in it and it fit ...that was a surprise ...Still dim as can be ..On the up side it does have a ultra warm light ..a little too brown for me .. kinda dirty .. but i'm sure some would like it .
The body is too cheap for trying to make anything out of it .. just buy a solorforce AAA/18650 for 8$ and be done with it .. it's an ok 3 dollar light ..i'd probably by more to resell but they are barely worth 5 bucks to an un-educated buyer ..Budget light folks will shrug and toss it to the kids . << that is mine with a lexan .. A Q-3 might make it a formidable glove box light .. not sure anyone would spend money to upgrade it . p-60 is worth 3 times the light . not worth the trouble
Well, that's the really nice thing about eBay - if the seller really put bad specs down it's easy enough to start a complaint with eBay and get your money back. I ended up with a Sipik Sk68 for free that way as they had rated it at 300 lumens instead of 200.
Well, this is what I consider abuse of the protection system and to be honest, quite miserable too.
Why, exactly? The light was advertised as "300 Lumen Cree Q5", no brand, no picture of any branding or model number. It was only when I got the light that I realized that:
1. It was a Sipik, as there are at least 10 different lights that use that exact same body styling
2. That the light didn't reach near 300 lumens.
Edit: This is the exact auction: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rt=nc&nma=true&item=170558513896&si=j4KplNcIABkBIz7mhsSNnxl9OS8%253D&viewitem=#ht_2309wt_1139
Similarly, in the above example there are models of the flashlight that are using CREE Leds and hit the specified lumens, and some that apparently are using low-power generics. If you purchase on eBay, you're entitled to that sort of protection.
Gods...that same seller has a torch with a Q5 emitter claiming to hit "up to 500 lumens"....
I can see both sides of this argument...
*On one hand as an informed buyer one knows full well that the output is exaggerated - Much like DX, and I don't here folks complaining when their Aura P7 doesn't hit the claimed 900 lumens. To take advantage of this may be considered bad manners.
*On the other hand, the seller (most likely due to ignorance) is lying out his ass....and should be punished. Anyone want to buy some ebay protected trustfires?
-Match
When I bought the light originally, I couldn't be considered an informed buyer. I had no idea what to expect.
And that's part of the problem. A few weeks back I went ahead and bought one of the "340 Lumen" X2000 lights on ebay. I knew full and well that it would not be anywhere near the 340 lumen it was sold as. It ended up being about the equivilent to my QminiAA on medium. I got a little pissed then got more pissed at myself for being pissed :(. Anyway, these guys get away with selling lights based on these specs to the average Joe who has no idea. I see no problem in calling these guys out when they over sell. Think of it as helping the common un-informed man
I'm a bit busy at the moment so all I have are some unedited and somewhat unimpressive pictures:
Meh: flat-surfaced and apparently uncoated emitter, not very bright at all, thin aluminum walls, thin o-rings, crappy and easily scratched lens.
Pros: works, threads well-lubed, takes 18650s without modification (light has two springs and tailcap may not screw all the way home with protected 18650s), will tailstand, comes with AAA battery holder (so I was wrong about that).
In terms of value, well, compared to the $7 TF-801 from a few months ago, it's wholly unimpressive. Judged on its own merits, it's still not great but then again, you often get what you pay for and for five bucks shipped, I'd say it's okay value. Chances are that if you're reading this, you won't be impressed with this light.
High-resolution pictures coming up in a minute, if my Internet connection decides to play ball.
That auction (listed in OP) is listed as over (with 115 sold), and when I click on "see seller's other items", 0 items are listed. I wonder if it's the seller or Ebay who yanked everything? Maybe this thread had something to do with it?
Belatedly, that auction is for yet another knock-off of the Surefire 6P design... American design from American company, probably the most common copy out there. Think Ultrafire WF-504B, 503b, C1, Solarforce L2, and a bevy of others. I see no reason why it couldn't be used as a 'flashlight body' or 'host' for a P60 drop-in, unless if they glued the thread heads, which is unlikely for this model (very likely on larger designs, maddeningly, case in point my Spiderfire P7).
I agree that the 3 x AAA is probably totally false and/or a mistake. (I'd be interested in a P60 host which takes 18650 and 3 x AAA, or even just 3 x AAA, for friends not for me). I'm holding up my 504B, which this most closely resembles, and there are some cosmetic differences, but the battery tube looks to be the same width. And they show now pics of a 3 x AAA battery holder.
Some trivia/catch-up for newbies: the 6P knock-offs ARE superior to the Surefire in one important way: most of them take an 18650 lithium ion battery. The Surefire was designed on using 2 lithium primary (non-rechargeable/use once and dispose) batteries, as the design dates back to when incandescent was the only game, and the extra voltage was needed (I think they also made 3-cell/9V -- and perhaps even 4-cell/12 volt? designs). So a 100% faithful replica will be too narrow, while a knock-off which can take an 18650, can also take two 3V lithium primary cr123 batteries if that's what your module calls for. White LED's are very well-matched for single-cell lithium ion cells (4.2V) and it looks like it's going to remain that way for awhile. A tip for newbies hunting on Ebay for "P60" compatible stuff: in addition to using the "P60" search term, try "6P" and whatever other word (flashlight, drop-in; I've found "bulb" is actually a surprisingly effective term). Ebay has the best deals on Solarforce L2 bodies (no drop-in), which is the way to go if you only buy a host. I have 3 flashlights which are P60 hosts (the 2 above + a WF-501B), and of the three, the Solarforce L2 is easily the nicest, plus seemingly having the best fit from head to reflector for heat transfer (still not great). I use it more than my Spiderfire P7 due to the size... and... now that I received my XM-L drop-in yesterday, it's now officially the brightest flashlight I own, easily brighter than the P7. I haven't been able to find L2's on Dealextreme actually in stock for years, and the old ones they have listed are exorbitant (old prices I guess).
I actually bought from Ebay the L2m combo, where you can use just a single 16340 rechargeable or CR123 primary (same size), plus an extension tube to use an 18650. In retrospect, the 16340 function seems silly, b/c the heads and switches of these are so long. Nice feature but probably should've gone with the single long cheaper tube. The crenelated bezel is also annoying and I stole the smooth bezel ring from my 504B to use on it, until I decided not to use a 'lens' at all anymore. Some of the Ebay sellers who specialize in this stuff actually are reputable and seem to understand us. You can even get compatible forward clicky switch assemblies there, albeit seemingly expensive for what it is ($10+ but free shipping) (any reviews/feedback on those welcome--need to make a break from reverse clickies). I agree that Ebay does give sellers good recourse, esp with these Asian high-volume outfits. On Ebay, item description is considered to be extremely important. We in the 'torch' community, esp budget flashlight community, have learned to be tolerant of puffery, wrong specs, and blatant incompetence/false advertising. But on Ebay, item description is like sacred. And why shouldn't it be. That is the most common reason for disputes, and underneath that, bad communication. Items not showing up at all (blatent fraud/theft) is rarely the problem. I think if you have 1000 flashlights to sell, you can spend more than 10 seconds on your description and make sure it's not poppycock with outright falsehoods in the already-lacking description. Battery specs vary by drain current so it's harder to prove. But Cree provides spec sheets, so if someone is outside of Cree's claimed max, there is no dispute. The question of "out the front" vs "published maximum" is much murkier; then again, what newbie will have an integrating sphere?
Another tip for newbies to get smooth rings off: Meritline occasionally has good deals (39c/free!) on fancy so-called "anti-static" tweezers. I have one where the pickup points are curved at an angle (straight would work too I think), and it's been invaluable for removing nutty-design flashlight parts. Needle-nosed pliers can work, but often those pliers' points aren't "needle-y" enough.
More trivia: the term "P60" is from the part number Surefire designated as the interchangeable module which went into their 6P flashlight. Maybe stands for "Part 60"? So, P60 actually being a Surefire part number, the politically correct term would be "P60-compatible" drop-in ;) (not like I care, just informatively).
Anyone know of a p60 host which takes 3 x AAA (and possibly 18650 too)? Would be nice to hook up a non-flashaholic with a new-age Cree light with an upgrade path. My XM-L is brighter at .9 amps (medium; about 4 watts) than my XP-G is at 1.9 amps (on high at about 8 watts)! WTF!
Solarforce L2i is made for 3xAAA and can take 18650. $7.99 plus $2 shipping is hard to beat at solarforce-sales.com. They seem to be out of sand color right now, so it's either glossy black or gunmetal gray (really kind of greenish). Might want to cough up $2.50 for a flat bezel.
Not as much "might" as "will" unless you want pockets destroyed.
