Not all 3 triple channel drivers will work because some use different I/O pins than others. There's 5 basic I/O pins
Two Channels (maybe originated with the Q8):
Pin #2 - typically the e-switch
Pin #3 - typically the AUX/switch LED
Pin #5 - 7135
Pin #6 - FET
Pin #7 - not used, or if it's a 2S battery driver, then there's a voltage divider circuit on this pin used to read the battery voltage level
For 3 channels, it's tricky because there wasn't a standard established. I'm not sure offhand how TA used the I/O pins. Might need a custom hwdef file, not sure. I'm not home so can't check right now.
At home I could probably do the research and build you an Anduril2 HEX file for that driver, or if someone else can. Best to post on the Anduril2 thread.
Is it a documented feature or a bug in Anduril that if the ramping mode setted to smooth ramping, and the lamp is in locked mode, the 1h lowmoon and the 2h highmoon, while it setted to stepped ramping, the locked mode is 1h highmoon and the 2h lowmoon?
1. Power on the light than set to smooth ramp (3c).
2. Power off.
3. 4c to lockout.
4. Now 1h lowest floor and 2h other floor.
5. 4c to unlock.
6. Power on the light than set to stepped ramp (3c).
7. Power off.
8. 4c to lockout.
9. Now 1h other floor and 2h lowest floor.
The 2 floor state swapped. Is this a(n) (un)documented feature or a bug?
I cannot reproduce your issue with Anduril 2. 1H is lowest floor, 2H is highest floor. Doesn’t matter which ramp style is selected. 1H is always lowest.
Both of my Anduril lamps behave the same way every time. Emisar D4SV2 and Astrolux FT02S. The code you linked means nothing to me, I’m not a programmer. Thanks for your confirmation of your lamp behaviour.
Maybe it’s my mistake but I was for sure it has Anduril 2. Does it have Andruil 1? I’ve never flashed anything. But the two flashlights have the same behaviour, settings and options (and maybe the same bug).
Thank you for clarifying it! The question is still open, is it a feature or bug in Andruil? Any other lights with Andruil behave the same way as D4S V2 and FT02S?
After Tom E mentioned it’s not Andruil2, I opened TK’s Anduril … 2? topic and found this in the change list: Lockout mode’s momentary function always uses lowest brightness first.
So after all i think it’s a planned difference between smooth and stepped ramp’s lockout mode.
Thank you, ToyKeeper for all of this! I'm usually not a huge fan of learning a new "language" to use a new tool, but I recently acquired my first Andüril Light and it's been a lot of fun to learn and use. I'm a fan. I've since placed orders for more than a few more lights with this U.I. Mad props.
Gonna be my EDC U.I. if I can remember to electronically lock 'em out. Just retrieved my LM-10 from my side to find out it's been on for who knows how long, luckily not on too high of a brightness level though.
Not sure if this is where I might find an answer (I suppose the answer is out there, but I can’t find it using search terms)…
Regarding “Beacon mode”, for Anduril 1 & Anduril 2,
what is the shortest time for beacon mode (ie. no light for xx second, up to what’s the longest time in-between each beacon flash)?
I seem to remember beacon can be as short as once every second (or can it be faster?) and as long as 10 seconds between flash (but maybe it can be set even longer?)
