The There Are No Stupid Questions Thread
1518 posts / 0 new
Colonel Light
Is swapping the LEDs of a Convoy S2 UV and an S2+ with a more powerful driver a bad idea?
JasonWW
JasonWW's picture
Last seen: 1 day 13 hours ago
The UV leds can’t take much power so don’t mess with those.
What led does the S2 have?
niajef
Last seen: 6 hours 16 min ago
im selling something i bought on amazon in a second hand market, the buyer is asking for the gift receipt. is there anything i should be concerned about? like is there anything they can do with the gift receipt that can be linked back to me in a negative way?
Agro
Agro's picture
Last seen: 41 sec ago
MoreLumens wrote:
Where to get extra thin 1mm 3535 mcpcb’s 16mm or even smaller?
You may get some thicker PCB and file them down to the desired thickness.
It’s a bit painful with copper, so for people who have them I’d recommend some Virence / Led4Power alu PCBs. These are hard to get nowadays though…
Colonel Light
It never produced much heat so I figured it wasn’t being worked hard.
According to the description on Banggood:
  • LG UV365nm LED 5W lamp beads are used.
  • The built-in drive is 7135×5 single file.
Scallywag
Scallywag's picture
Last seen: 4 hours 53 min ago
As far as I know, about the best they can do is attempt to return it to amazon for the original purchase price.
That said – in the secondhand market, if people want weird things, I usually just consider that it’s either too much trouble, they’re up to something, or both. Hopefully for you it’s an option to just move on to a less suspicious buyer.
JasonWW
JasonWW's picture
Sorry, I thought you were saying you had two different lights.
Colonel Light
Appreciate you trying to help. I have three in total: the S2 UV, an S2+ with 7135*8 driver and T6-4C XML2, and an S2+ with (if memory serves) a 7135*6 driver and a U2-1A XML2.
JasonWW
JasonWW's picture
Xml2 leds can handle up to about 8A. So you can swap the driver on them for sure.
The UV leds are not robust at all. They can not handle high amperage. So I would not swap their driver.
Maybe somebody that knows what specific LED is used can give us some numbers as to how much power it can handle. My guess is no more than 2A.
Scallywag
Scallywag's picture
I’m not sure on the current handling, but if you search around BLF some you’ll find that all the UV LEDs can’t handle much heat, either. Even treated nicely they don’t have great runtime ratings. You can probably run them at 3A briefly and get lots of power – but, at least for all the examples I’ve looked at, you’re also going to need a 2 cells+buck driver or one cell and a boost driver to hit much current on them – the forward voltage starts high and ascends rapidly.
Starkm32
Starkm32's picture
Wouls someone please tell me how to post an animated gif for one’s avater? Doh
JasonWW
JasonWW's picture
I’m going to guess that you first need an animated gif that is no larger than 85 by 85 pixels. Then try to upload it in your account settings.
raccoon city
raccoon city's picture
Last seen: 4 hours 57 min ago
JasonWW wrote:
I'm going to guess that you first need an animated gif that is no larger than 85 by 85 pixels. Then try to upload it in your account settings.
Yes, and your avatar must also be under 30 kilobytes.
MoreLumens
MoreLumens's picture
Last seen: 12 hours 37 min ago
I got Sofirn C8F green for under 19 €‘s some time ago and thinking of modding it a bit. Got SS bezel coming which should fit it, but not sure what leds to get for it. I thought about sw45k’s, but would they work with this and how many lumens they would put out? I dont need max lumens, just to make it a really nice general use light.
Anything else I could do with this? Swapping wires too? Being a C8-model there should be a wide variety of different drivers and other stuff too? Lighted tailcaps? Open for all kinds of ideas and every bit of help is appreciated, thanks.
Colonel Light
Thanks to Jason and Scallywag for their input on UV LEDs (I left it as is).
I just recieved an Emisar D4v2 with 3500k E21A emitters, I was wondering if it’s “normal” for them to immediately turn blue on turbo with a high drain battery?
I’m assuming that it has the Noctigon driver which delivers 5A on turbo.
Rayoui
Rayoui's picture
Last seen: 17 hours 52 min ago
No, that is definitely not normal. I wonder if your driver wasn’t correctly flashed with the NoFET firmware.
Colonel Light
The LEDs are already burned, I think I’ll send them an email.
Templogin
Last seen: 13 hours 19 min ago
Battery question.
Some of my 14500 batteries have a “pronounced” pip at the positive end and some don’t. I know the trick of using a small round magnet to make the pip longer. Is there something different about these batteries internal make-up? Is there any reason that thay are not all made to a standard length?
Thanks
Boaz
Boaz's picture
Usually there's
flat top
 button top non protected
 and then button top protected
I'd suggest a solder blob over a magnet any day .
 the thought of a possible loose magnet in a light gives me chills .
 you can do a decent solder blob in exactly  6 seconds ...Solves a myriad of length issues ..makes life enjoyable again .:)
Templogin
Excellent. Thank you Boaz. I feel an enjoyable life coming on.
Sarri
With my Olight Perun Mini, can I put one of those little magnets on the top and then safely charge it in a normal charger like my 18650s?
Pretty sure I can, just wanted to check…
lucifer
Last seen: 8 months 3 weeks ago
Has anyone ever made a flashlight out of these 250-315nm UV LED parts, or these 275nm UV LED parts? Or have a reference to a list of materials that can be successfully built and used in the 250/275nm range? Mod for a Convoy S2+ would be awesome but I don’t see a reference here or elsewhere.
Scallywag
Scallywag's picture
There are UV-C flashlights out there, but I can’t think of any builds on here (at least off the top of my head). If it’s anything like the ~400nm UV LEDs, then you can expect low power, high forward voltage (indeed, looks to be solid 2S territory on the ones you linked), and bad longevity.
If you’re planning a build, keep them within rated spec, make sure they are cooled well, get a constant current circuit at the correct voltage range, and make sure your optics are transparent to the wavelength you’re using (for example: polycarbonate optics block most of the normal UV light we deal with (back in that ~400nm range).
Oh, and use eye protection. Skin protection, maybe, too? I can’t remember.
For what purpose are you looking into a flashlight at these wavelengths?
Agro
Agro's picture
Yes, you need proper eye and full body skin protection. I won’t advice you on what is proper (I was never interesting in using UV-C myself) but stress that UV-C is highly harmful.
lucifer
Just to do it, show off to strangers on the internet or friends. I’d try to build an x-ray flashlight if it was financially feasible, tho I see LEDs seem to bottom out well before x-ray territory. Probably different tech altogether and not a flashlight type of device.
EDIT: There are DIY x-ray machine builds available. Not a flashlight at all, but still feasible if you have some extra cash, time, and no concern for personal safety.
lucifer
ReactNation wrote:
Curious about your job and position? Smile I’m just looking for a job and now I am worried about this issue very much
About the feasibility of UVC flashlights?
Colonel Light
Why does a 21700 battery exist when a slightly shorter 21650 would fit into existing chargers?
raccoon city
Good question!
Robin Dobbie
Last seen: 1 hour 36 min ago
Not sure even a single one of these lithium cells was originally conceived of with consumers in mind, much less handling them and charging them individually.
Oli
Last seen: 3 days 6 hours ago
Tesla and Panasonic thought it was a good size for their use. That was after using 18650s as other car makers did for many years. And now they’re moving on to the 4680. So yes nothing to do with flashlights or chargers.
