How many phones even have an option to replace the battery? And even for those that have replaceable batteries finding a decent one thatās also inexpensive is not easy.
a CHARGER can damage a BATTERY ( for instance by not terminating charge at 4.21V )
but the situation with a phone is not that
the CHARGER is inside the phone
the outside thing with USB on it, is just a power supply
that might damage the phone or its internal charge section, if it was severely over 5V
under normal conditions though it does not do that
still you would have to know what it did and when
speculating later does not prove anything
Thank you for your explaination, I feel ok with the new RAVpower one now _,
an update to all of you : Anker A2023 charger I used to charge my Iphone 11 before, I gave it to myā¦ā¦wife, to let her can charge her Iphone 11Pro + Ipad, and after 2 months, she also informed me that she saw her iphone gets the shorter battery time ( _ I will never explain , I just purchased a new iphone charger for her from Apple store)
for an i phone you canāt really get oem battery no matter what the seller says, i tried several āoemā from amazon and ebay, all looked legit, but performed worse than old one i replaced, i think only apple service would put oem cell, but even that is not 100%, pretty sure other phones are no different,
my wifeās iphone 11pro with usb C included charger, charges the phone from dead to full in a bit over an hour, but it does not get that hot, wireless charge however makes it very hot. i had a ipad case with wireless charger, that i most of the time kept on its base, it got so hot that over time batteries inflated like pillows and the screen opened like a book.
it is quite dangerous. I thought Anker is a good brand name for the charger product so I selected it before, but after your post, I think I also should have a check my RAVpower charger also. When I used SamSung Note 9 before, I used the different chargers without any prob, but after changed to Iphone, I just faced the prob with the Universal USB charger ( the original charger of Iphone may be better ?)
Its very rare that I side with the chinese sweatshop but this is not the fault of Anker. Apple batteries are complete crap. IMHO, this is by design to get you to keep upgrading your product. Lithium batteries can and will last ten years. There is no reason the phone battery should be any different. Anker has nothing to do with Appleās inferior technology.
So Apple puts a battery in the iphone. The battery is not replaceable and they tell you if you try and do so, they will void your warranty. So when the battery fails after a year, they expect the customer to throw their phone out and lay out another $1000 to buy the same Apple crap again.
How many times are consumers going to get screwed before they say enough is enough and switch brands.
Do you remember Appleās āgenerousā phone recycling program? They got people to send in their phone for free to be properly recycled.
Guess what, Apple made $$billions from that program. Turns out there are a few grams of gold in each phone. Guess they did not tell you that BEFORE you sent in your phone .
Do you remember Apple was caught using software that purposely locked out the phone battery after certain time forcing people to change phones. They claimed it was for the consumers safety.
DID YOU KNOWā-Apple products are made by a Chinese company named Foxconn. Foxconn is one of the biggest sweatshops in China. They made the news years ago because their employees were committing suicide jumping out the window at the workplace. It seems they thought the 18 hr work day was excessive.
others phones are no different, equivalent Samsungs, pixelsā¦. are no cheaper than apple, have the same non user replicable battery, and will void warranty if you open them.
as far as 10 years battery, yea, any li ion can do that with 40/80 cycle. but with 10 or less/100 cycle you only get 300-500 cycles, with lithium cobalt chemistry, i still have working first gen ipod touch, it is definitely older than 10 years, but i almost never use it. the battery is still pretty health for its age.
Iām not sure if my āguess explanationā would be right or not:
but it could be the Anker A2023 has āvoltage boostā feature ā which means, it will attempt to supply as much charging current with slightly less good cables, unlike a less powerful charger.
This would mean the device being charged is charging at a slightly faster speed (a bit higher current) than your usual charger ā a faster charging current will result in a bit more heat to the device/battery, so that could degrade the unit slightly faster.
But I think this shouldnāt effect the battery too noticeably (unless itās overnight charging every time?)
In post #3 I suggested you not do that. Yes, itās more convenient. Butā¦ā¦it ends up sitting for MUCH longer at 100% charge, which is harder on the battery. That is just a fact of lithium battery life. This would be especially true if itās capable of fast charging and the Anker allowed that.
Manufacturers are into convenience, not long term reliability in hardly anything any more. Consume, consume, consumeā¦ā¦an make more trash.
If you want it charged sā¦lā¦oā¦wā¦lā¦y over night get a really low output (like 0.5A) USB and a 6ā cord. Thatāll slow it down.
This is nothing new. Apple is one of the most uncompetitive companies out there. Even people trying to fix older apple products are given grief by apple. Worse yet, other companies are starting to emulate them. At this point, the vast majority of smartphones are disposable. Use them for a couple of years and then replace them with a new one. If you donāt, theāll slow it down so much, youāll want to buy a new one anyway. Tablets look to be going the same way. Itās sad that this is the way it is, because thereās no need for it be like this.
Wow, thatās some frightening damage to the batteries. Iāve read that wireless charging does incur more losses, but I canāt imagine how hot it would have to get to do thatā¦
On the plus side, now you donāt need to pry open the iPad to replaced the batteries - the batteries did the heavy lifting for you!
Wellā¦ā¦ thats all fine and dandy but outright just singling out apple is flawed and a false narrative, EVERY phone creator has the same sealed phone with a non replaceable battery which ALSO has a limited life span based on charge cycles as its all limited by current battery technologyā¦. So āSwitchingā brands isnāt going to change that fact and indicating such is misinformation. Samsung, LG, Xiaomi, Huawei, Pixel, Sony etc ALL manufacture phones with a battery that cant be replaced and opening a phone in an attempt voids their warranties too so everything you said is moot.
Also misinformation, apple indeed had a protocol in the OS which throttled performance as battery degraded which was an attempt to maintain duration of use over performance. Not saying it was a good thing they did that either but you falsely framing it is as forced obsolescence is misinformation IF anything Android is worse as they discontinue software support after 2 years MAYBE 3 if your lucky, Apple on the other hand has software support for most devices for 5+ years after initial production.
DID YOU KNOWā- Foxconn also manufactures for not just Apple BUT many large companies like Sony, Microsoft and, Nintendo ? Singling out apple is a poor way to spread the message about how poorly Foxconn treats employees.
Just dispelling misinformation that some āAppleā haters seem to keep spreading without looking at every other brand thatās doing the exact samething and pushing a narrative that they are better than Apple due to āXā cause of āYā but in reality all the other companies are also guilty of āXā.
And yes some chargers can ātechnicallyā shorten battery lifespan but that has a lot more to due to user negligence, personally I tend to use OEM charging blocks or the usb ports on pc to ātrickleā charge a device rather an cram the device with as much juice as quickly as possible.
You sound very angry. You can Google everything I said and you will see I am right. IPhones are made by foxxcon. Foxxcon employees did commit suicide by jumping out windows , apple purposely mislead their customers. When they were caught they tried to cover it up. Go ahead and Google it if you want proof.
Dudeā¦. you didnāt read anything I said at all did youā¦ or if you did you choose to ignore facts to promote a false narrativeā¦ Why do you ignore that every phone manufacturer did and does what Apple did but just focus only on Apple in particular ? As I already mentioned while refuting all misinformation you decided to spread, you derailed a thread which was only asking if it was possible for a charger to damage the longevity of a battery with your propaganda.
