Sofirn C01S SST-20 4.000K 95CRI / Low-High version available again!
Did you (or anyone else) order the low->high from:
- the generic Page Not Found - Aliexpress.com
I would like the low~~high one, but the first link offers extra discount for ordering 3 at once, so if those are also low~~>high that would be extra nice.
Edit:
In the opening post is says this:
So I guess all but the black one are low->high, no matter where you order it? Maybe the only difference between above 2 links is the BLF engraving?
I ordered using https://www.aliexpress.com/item/32952525303.html because it was slightly cheaper and got low>high. I don’t think the engraving is different, no idea why they have two listings…
@Bob.:
I ordered the two red mentioned earlier, and I have an ongoing order for one orange + one non-ano from the Sofirn AE store.
Thanks guys, seems there is not any difference between the two different listings on AE then.
I just got the C01S and I can’t seem to get it into high mode at all. The manual says how to do it, but something isn’t working…
You tried a fresh cell?
Earlier in this thread i saw some pictures of the driver board, but no real details—has anyone done a deep dive into the boost and controller circuits? Is it using Torex Semiconductors?
So what is the long term verdict on the unanodized version? Its the only one I haven’t got.
What do you want to know about it? It’s a C01S without anodization, just pure aluminum.
Doesn’t a anodization also act as a surface hardener?
Yes, it does.
Got together another order and gonna try one unanodized.
I’ve had a non-anodized (raw) C01S since May 2019 and it’s actually still looking pretty nice. Granted, I take pretty good care of my lights. But I have been carrying it in my shorts every evening for the past nearly 2 years, using it daily. I really like the no-nonsense 2 mode driver and I’ve outfitted it with a trit and magnet.
Looks good can’t wait for mine.
Got my order from the 7th. Pretty fast. The unanodized one has sharper knurling. Think will order more unanodized.
There was a question which inexpensive honeycomb TIRs would fit:
Left: Original optics, right: ‘AE’ optics
https://de.aliexpress.com/item/32989679045.html?spm=a2g0s.9042311.0.0.41c64c4d20RAz0
$1.18 incl. s&h, 5 pcs.
It is not the quality of those TIRs someone found in Bulgaria (artifacts at the white wall), but you’ll see no artifacts in real situations. Much, much better than the original optics with its rings. Can recommend them.
45°
Maybe these Yajiamei lenses would work as well?
@Unheard: how did you manage to open the head and hence swap the optics?
It seemed to me it was glued and therefore impossible to open.
There’s red threadlock. Brute force and maybe heat helps.
