I would probably pick the SBT90.2, I think for me it is the better general purpose beam, I love having that extra spill and more loosely defined hotspot, plus it is collimated much closer to the flashlight so the beam is useable at very short distances the W1 has a donut hole 16 inches away. The W1 does also have some minor rings from the reflector, the SBT90.2 doesn’t have this issue.
Normally I would say no, but with this driver I do think it is worth the extra $50. 6 amp current regulation really makes the SBT90.2 shine. If you are looking for the longest throw go for the W1, it has a nice tint, not super cool until you go into turbo. But the SBT90.2 fits my needs better and 1800 lumens with current regulation is great and 4000 lumens with the FET.
I see you say the charging work with USB PD, does that mean ‘USB C to USB C’ cable? Do you know if K9.3 also work charging with PD? I read many light need USB A to USB C cable to charge so this is good finding.
It will charge with USB C-USB C and USB A - USB C, so virtually any charger type will work! The K9.3 works well with USB PD and standard USB just like the new Fireflies flashlights. I did look at the drivers in the T9R and NOV-Mu a bit and noticed loneoceans selected a Texas Instruments BQ25616 to handle the USB charging. It looks like this TI controller supports USB OTG with a built in boost converter capable of 1.2A charging, but the flashlights do not support this mode. It looks like maybe pin 6 was left disconnected to the TI chip (but it is hard to tell without pulling out my microscope), I wonder if there is a way to pull the pin high and get it to work… or if there was a reason the feature was left out.
One reflector has very minor plating contamination, it looks a bit like paint over spray but VERY minor and not noticeable in the beam (actually my K1 reflector came in worse condition). The other reflector has a minor scratch that looks to be from assembly. There are a few rings in the beam of the Osram W1 and I am not sure if that is coming from the reflector, I think it is though. The rings have a diffraction pattern to them like it is from the reflector not being perfectly smooth. They appear to be metal.
The reflector appears smooth but you can see some “stepping” from the machining so I do think better reflectors would help the rings, but the focus is tight and the beam shows it, and that is what matters.
The new version of Anduril is great, a bit of a learning curve for sure and I have the diagram ready to view on my phone, but no complaints.
There was a brief discount for long term buyers, but that is over and there seems to be no intention yet of another discount code. I think these flashlights offer a lot of value for the price without any discount, if you compare say the T9R to the K1.
You must be the first one to receive them! I’m still waiting for my order. Which emitter did you get for the NOV-MU? Measuring 4400 lumens in the TA tube means it is 5500 lumens when compared to the industry wide inflated lumen ratings. Real impressive for a 22350 10A cell and 95+ CRI.
The tube I received was for a 21700 cell, and I put a 40T in mine for testing the NOV-Mu which yes tested 4400 lumens on my TA tube. This thing can put holes in black paper almost instantly, without optics and the LEDs in a tight pattern, it has serious nut burning capabilities. The tint seems comparable to my D4V2/KR4 mules that have the 4500k E21A.
