There was a brief discount for long term buyers, but that is over and there seems to be no intention yet of another discount code. I think these flashlights offer a lot of value for the price without any discount, if you compare say the T9R to the K1.
You must be the first one to receive them! I’m still waiting for my order. Which emitter did you get for the NOV-MU? Measuring 4400 lumens in the TA tube means it is 5500 lumens when compared to the industry wide inflated lumen ratings. Real impressive for a 22350 10A cell and 95+ CRI.
The tube I received was for a 21700 cell, and I put a 40T in mine for testing the NOV-Mu which yes tested 4400 lumens on my TA tube. This thing can put holes in black paper almost instantly, without optics and the LEDs in a tight pattern, it has serious nut burning capabilities. The tint seems comparable to my D4V2/KR4 mules that have the 4500k E21A.
In my mind it is the ability to charge and use the light at the same time. I like being able to use my light on my night stand and charge it. Also some of the K1’s (SBT90.2) use a linear fet vs constant current buck on the Fireflies. I guess my point is, as the battery voltage starts to drop in the K1, output will drop. In true constant current regulation as battery voltage drops, output should be able to stay constant until the circuit can’t regulate anymore.
With both linear and buck the output will drop once the cell’s voltage approach the forward voltage of the LED, probably sooner for the buck actually since they usually have a higher voltage drop. For the SBT the Vf is low (~2.95V) even at 6A, so it’ll only happen at the very end, same for the E12R, NOV-mu thanks to the high number of LEDs.
Aside from that I got a shipping notice yesterday.
Well it’ll just give you a wall of light with not much throw. This means it would also be more efficient as there’s no light being lost while passing through optics. It’s designed for photography and close range use.
If you want something with more throw, the E12R or E07 G2 219B would be a better choice.
I appreciate your answer but I thought photographers use special (expensive) lighting equipment for their work. I never saw a photographer using a flashlight.
What? I have a Sony A7Rii and have owned many Canon DSLR and I use flashlights for photography a lot! A floody E21A mule is the perfect lighting setup, mounted in a softbox. I have some purpose built modeling lights, but the color accuracy here makes a huge difference. I am not saying I use them for all setups, but they can be useful for taking a quick photo without having a flash mounted, if you are around family as an example. A really good flood setup will take great photos, adding an additional layer of diffusion helps. I also have really large godox flash units that I use, but don’t discount really high cri flood setups being useful in portraiture or taking product photos.
Blue and red LEDs on the switch, they are blue and red while charging and turn blue when the flashlight is fully charged. They do not turn on during use.
Not a gimmick. I use my floody flashlights for indoor photography for work. I use it several times a week when doing inspections. Currently I pocket the KR4 E21A version for this purpose but will be replacing it when I get the NOV-MU which will be much better suited for the task with the longer lasting 21700 cell, more efficient driver, and the better situated emitters that should give it a wider and less obstructed spill.
When I first started, I use conventional reflector flashlights and the light just blows out the image. It was horrible. The E21A mule works really well and allows the pictures to retain great detail.
The NOV-MU will also piss over the popular (and overpriced) LumeCube photography light in terms of lumens output. The LumeCube will probably still have better waterproofing and can be remotely controlled though.
