I’m not sure on the current handling, but if you search around BLF some you’ll find that all the UV LEDs can’t handle much heat, either. Even treated nicely they don’t have great runtime ratings. You can probably run them at 3A briefly and get lots of power - but, at least for all the examples I’ve looked at, you’re also going to need a 2 cells+buck driver or one cell and a boost driver to hit much current on them - the forward voltage starts high and ascends rapidly.
Thanks to Jason and Scallywag for their input on UV LEDs (I left it as is).
I just recieved an Emisar D4v2 with 3500k E21A emitters, I was wondering if it’s “normal” for them to immediately turn blue on turbo with a high drain battery?
I’m assuming that it has the Noctigon driver which delivers 5A on turbo.
Some of my 14500 batteries have a “pronounced” pip at the positive end and some don’t. I know the trick of using a small round magnet to make the pip longer. Is there something different about these batteries internal make-up? Is there any reason that thay are not all made to a standard length?
With my Olight Perun Mini, can I put one of those little magnets on the top and then safely charge it in a normal charger like my 18650s?
Pretty sure I can, just wanted to check…
Has anyone ever made a flashlight out of these 250-315nm UV LED parts, or these 275nm UV LED parts Or have a reference to a list of materials that can be successfully built and used in the 250/275nm range? Mod for a Convoy S2+ would be awesome but I don’t see a reference here or elsewhere.
There are UV-C flashlights out there, but I can’t think of any builds on here (at least off the top of my head). If it’s anything like the ~400nm UV LEDs, then you can expect low power, high forward voltage (indeed, looks to be solid 2S territory on the ones you linked), and bad longevity.
If you’re planning a build, keep them within rated spec, make sure they are cooled well, get a constant current circuit at the correct voltage range, and make sure your optics are transparent to the wavelength you’re using (for example: polycarbonate optics block most of the normal UV light we deal with (back in that ~400nm range).
Oh, and use eye protection. Skin protection, maybe, too? I can’t remember.
For what purpose are you looking into a flashlight at these wavelengths?
Yes, you need proper eye and full body skin protection. I won’t advice you on what is proper (I was never interesting in using UV-C myself) but stress that UV-C is highly harmful.
Just to do it, show off to strangers on the internet or friends. I’d try to build an x-ray flashlight if it was financially feasible, tho I see LEDs seem to bottom out well before x-ray territory. Probably different tech altogether and not a flashlight type of device.
EDIT: There are DIY x-ray machine builds available. Not a flashlight at all, but still feasible if you have some extra cash, time, and no concern for personal safety.
Tesla and Panasonic thought it was a good size for their use. That was after using 18650s as other car makers did for many years. And now they’re moving on to the 4680. So yes nothing to do with flashlights or chargers.
