How to fix this Sound issue in Windows 10?
Hello Friends,
I am using RGB bluetooth speaker. Whenever I connect it with my phone it works perfectly, but when I connect it with PC, the sound gets high intermetendly. Will the issue get resolved? If sound equalization is enabled. If so how can I do that.
What Bluetooth version does your PC support?
Probably your phone supports a much newer version
This happens because Windows automatically lowers the volume when it needs to play a system sound. You will have to look at your sound properties and change a few settings. Very difficult for someone to walk you through this in a forum reply.
format c: /q
Thanks for the help guys. I have resolved the issue following the steps here:
silicophilic. com/loudness-equalization-windows-10
