Here is Barou’s awesome lantern
I am thoroughly amazed. They are beauties and I can’t believe they are functional, nice! Your videos are simply awesome, very well done. The E001 is my favorite.
Wow! This is the next level!
They look real great.
Really interesting lamp, hard to take your eyes off it once you look at it. Really clever concept.
love it!
There is a link in my signature on how to post pics on BLF.
Such creativity! It looks great!
That is awesome. Very creative, and well executed.
At first I thought it was just quirky, in a charming steampunk sort of way, to have light bulbs hanging off the side of a kerosene lantern. Then I realized there were heat pipes in the middle and figured out what was going on before reading the text.
Are they dimmable?
Are you just using a couple TEG’s in series to get an appropriate voltage to run the LED’s and/or regulate down to USB voltage, or is there a boost circuit in there? Are the electronics off the shelf or custom? I ask in part because I have a few TEG projects in mind to tinker with and am interested to know what worked well for you.
Thanks for sharing this project.
Welcome to BLF Barou
Very nice Lantern. Does it use more than 1 Peltier ?
I will bet you have taken it apart a time or two. It is definitely a keeper.
I hope you have fun here, Barou!
Thanks guys for your kind words.
I intend to build a blog with a full technical description of those Thermo-lanterns.
A patent is already filed, so there is no reason to hold anything back.
My goal is to give it a shot for fundraising at Kickstarter. (either for making steampunk thermo-lanterns as those depicted, but more refined i guess or to go mainstream and develop cheaper thermo-lanterns in greater production like an alternative to mantle lanterns for general use or indoor use)
Their advantage is less power consumption almost 1/3 of fuel for equal luminosity (for current efficiencies) , not very hot spots on that lamps, low glare, subtleness
Their disadvantage obviously is their complexity.
Time will tell.
Just to answer the curious ones, it employs just one 40x40mm TEG element (Peltier) by II-VI Marlow.
Steampunk is only for the looks. It is a really functional piece as already told.
No, the light is not electronically dimmable. It is analogic dimmable by just turning the flame down. It takes a bit to do so due to thermal inertia, but who is in a hurry?
Those lamps have been made so as to be also power generators( 4 watts out max) (because i could )
Circuit employs OP-AMPs, for dynamic impedance matching, a 2 stage boost converter (in that version) for a low voltage output rail and a higher voltage output rail, a burner fan regulator (knob on right side), USB voltage regulator etc.
The circuitry is totally custom made - hand drawn concept, components searched in databases and purchased, arranged and tested at breadboard, then Eagle drawn to specific pcb dimensions, PCB printed, hand soldered, debugged, proceed to version 2, version 3 etc
i have some experience in custom made circuitry, but it takes me a while to do properly.
Besides electronics, a lot of those lamps parts had to be created and refined by experimentation, as the heat exchanger, the chimney, or the burner.
Great efforts were given for achieving efficiency in every aspect of it, having the final look in mind always.
When you are ready to sell, I will be there.
Awesome job! reminds me of the Apocalypse lantern i built a few years back.
That is a work of beautiful art!
They look fantastic, and kerosene powered, so cool!
Very cool!
Hello,
The time is about right.
I am launching a crowdfunding campaign Octomber 2021 in order to bring my lamps to production.
Campaign’s main theme is my thermoelectric lamp model
Also will be available the electrified lamps (converted per specs)
Learn more at
www.baroulamps.com (thermoelectric lamps)
https://electrified.baroulamps.com/ (electrified lamps)
Cheers,
Barou
Dude, you are an artist and a light master! I have a couple of old railway light the I would love to mod but I am afraid to tinker with.
Hello mattlward,
Thank you for your kind words.
As everything in life, you start small and keep going
Cheers,
Barou
It looks beautiful. Love the steampunk aspect of it. Absolutely fantastic.
