I prefer the V2 5D here, which is 4000K. It's beam's tint is consistent, usually a slight rosy color, to me (important to note personal pref) it's about the best beam/tint combo out there.
The difference in brightness will be completely unnoticeable. The 5000K might seem a bit higher output since higher color temps are a bit harsher, but even on paper they’re extremely close in output and the 5000K won’t actually illuminate anything better.
TK (or any owner) - that switch on the D4V2, can you describe it?
Is it similar to what Manker uses in the U1?
Theirs is a soft rubber dome (which can come loose),
over a beryllium/copper dome,
over a pair of contact pads.
If the dome does come off, the beryllium thing gets lost and the switch is done for
and because og Manker’s assembly, you cannot replace it, and probably could not find the right part.
I relay enjoyed using this light, but now for some unknown reason the switch has stopped responding reliably, sometimes it works and the light functions, but most of the time no response, checked it, made sure it wasn’t in muggle mode, re set it but still, click click nothing - most of the time
Emailed Intl- outdoors and had a reply offering to sell a replacement switch as its out of warranty - however the bezel is on tight and wont be easy to remove without causing damage
You need to get the retainer ring out, then grab the cables with some fine tweezers and resolder the button PCB. Obvioulsy you need a new switch boot, too.
You’re in luck: you got the flush retaining ring so the light should be repairable. The flush retaining ring is removable. Unlike the raised retaining ring which I found impossible to budge.
Get a small Victorinox mini pocket knife, open the nail file.
The tip of the file should be a flat screwdriver with rounded edges.
Coming in from the side, insert it under the retaining ring just above where the rubber switchboot sat. Once it is wedged in, use it as a lever to lift up the retaining ring. The retaining ring is press-fit and should lever right up.
Next step is to desolder all the wires to the aux board and the star. Only attempt this if you have soldering skills and a fine tip for your soldering iron available. The wires to the aux LEDs are tiny. Before desoldering, take a picture so you can make sure to get every wire back to the right bondpad when reassembling.
After desoldering, remove the aux board and the star. Then insert a toothpick or other tool into the wire whole and push the driver out of the head. Once it is partially out you should be able to access to tiny wires which go to contacts on the underside of the red switch. Assuming those bondpads didn’t rip off the switch, soldering the switch wires back on. Reverse the process to reassemble.
Notes:
Since the rubber switch boot is destroyed you will need to obtain or make a replacement.
Also, if the switch retaining ring eroded the head coming out, you might find it may not stay in place. If you experience this try adding some super-glue gel between the retaining ring and head.
Due to the numerous small wires involved I wouldn’t recommend attempting this repair unless you’re an experienced modder. If not, you might want to contact Emisar about having them repair it.
It can be difficult threading the 4 aux board wires plus the 2 LED wires through the hole in the head and the star. If you have difficulty, solder some long narrow gauge guide wires onto the ends of the wires and then pull the guide wires through. Then desolder the guide wires.
I have had 4 Emisar / Noctigon torches stolen from me.... wish they would start putting serial numbers or BLE locating functionality inside. I am sure of where 2 went but have no way to prove. These cost a good bit of money and anything would help....
