7 hours for me is about perfect, 8 or longer and I feel sluggish all day. 6 and Iâm a bit tired but less than 6 and Iâm an asshole.
Kind of been touched on already, but sleep hygiene is very important. I donât have caffeine after midday, else Iâm screwed.
I try to go to bed and get up at the same time every day, I find that âawkward zoneâ where itâs too late to start on something else and too early to go to bed is best spent reading (paper books- no screens!).
I hope you find something that works for you, good luck!
Sounds dreadful! There was a case of infrasound pollution a few years ago down the SW of the UK, accusations were mostly made against a mine in the area, it might be worth looking into whether there is any mining activities near you?
Between 7 and 8 for me (I prefer 8). If I get less I feel like I`v got Flu next day and if I get more I tend to have a headache. I don`t drink alcohol, smoke, take pills or even have cafeine, I read in bed half an hour before sleep using an Incan flashlight and go to sleep quite quickly.
Wonât kill ya dead or nuttinâ, so you can always try it.
But itâs not a sleeping pill, itâs not like getting slipped a mickey or anything. You have to be ready for sleep, and itâll come if it otherwise canât. Itâs kinda ZenâŚ
Iâm somewhere around 5h but using 10mg of Melatonin will knock me out within 10min. After i woke up (even after 4hours due to alarm/work) iâm totally refreshed, brand new person.
What i have found is that using EU (kids) dosage 1-3mg will only make you angry. American size pills are perfect.
If melatonin works for you, great! Iâve tried 2.5mg, 5mg, and 10mg melatonin⌠zero effect. (Maybe a slight headache with 10mg sometimes, though that might just be my imagination.)
Someone else I know, can take 5mg melatonin and be out within minutes.
I suppose it all depends what the underlying cause of insomnia is, and how your body reacts to melatonin.
Other things to try: OTC sleep drugs containing diphenhydramine, or just take Gravol (or generic), itâs the same thing and a lot cheaper. It seems to make most people drowsy. Hit & miss, IMO, but itâs worth a try. I find that if it works, it works well; if it doesnât work, it makes the night awful.
After that, you pretty-much have to get a prescription for something stronger. There will be some prescription drugs that will work (it probably will not be the first one you try), but they come with more serious issues of dependency.
Non-drug approaches are various behavior-modification therapies. Most is common-sense, but for people without common-sense it can help a lot, and it has no down-side.
Stay away from psuedo-scientific nonsense, or âancient Chineseâ medicine. All those new-age things will do is take your money.
Finally, be aware that not everyone needs 8 hours of sleep. Some people can be perfectly fine with 6 hours or even less. If you wake up after 5 hours of sleep and feel wide awake, just get up and enjoy the extra 3 hours of free time that day!
Iâve struggled getting a good night sleep most of my life, and hate taking meds too. So I found a combo of things that all together, can get me a good night sleep quite often, which is a miracle.
I highly recommend trying them all for a week before you give up.
This was the first step for me, it will probably be the last step for you⌠A doctor finally ordered a sleep-study for me years ago, and we discovered I also had severe sleep apnea. Itâs like snoring, except you just donât get enough air, leading to you (unknowingly) staying partially awake all night. You would thing you would figure it out, but you donât. My wife didnât even notice. So they âprescribedâ me a CPAP. Itâs a fan and mask thing that uses room air to simply push back against your breathing and keep the airways open further. It sucks to need, but is totally worth the deeper sleep.
2) Low lighting after 6pm. I now have indirect LED strip in all rooms, but a good life-hack for you is to just shut off the light in the room you are in⌠and instead turn on the light in the room next door. The flood of light coming through the doorway is plenty once your eyes adjust. Also after 6pm, use the settings on your PC and phone to dim the backlight very low. I go to 8% brightness.
3) All the crap you have already been told, establish a schedule and stick to it, donât drink caffeine after 6pm, blah blah.
4) An hour before bed, lower the thermostat 2 degrees F for the night. Being warm and cozy does help me fall asleep, but itâs not worth the poor sleep I get later. This trick works because your body can regulate itâs temperature without waking your mind. It simply increases or decreases blood flow to a cool arm or leg, instead of waking your mind half-way to deal with the covers. Typically I just leave one foot exposed to cool air.
5) 30 minutes before bed I take 2 Luna pills. They are almost identical to the cheaper Sleep aid from Walmart, but for some unfortunate reason, the expensive Luna works much better, and with only 6mg of Melatonin instead of 10.
6) Honey Nut Cheerios. I donât know why, but it really helps me sleep.
7) Relaxation breathing. At this point I am in bed, but often can tell I am not melting into the mattress properly. So I breathe deep, then slowly let it out while focusing on a muscle group to relax. Then repeat with another muscle group.
If Iâm lucky I get 5-6 hours sleep, but usually this is broken. At worse 0 hours, even with co-codamol. I can be in pain all day and as long as Iâm busy it doesnât bother me, but as soon as I try to sleep its there.
Seriously? Itâs the most common anti-histamine there is. On the shelf of just about every store, in one brand or another. For allergies, motion-sickness, and sleep. I live in a nanny state too, but I hope it doesnât get that bad.
Then again, there is other stuff I have to order from the US, because we canât get it here any more. Try Ebay to see if you can get it that way.
When you describe brain fog and say you slept 8 hours and it didnât feel restful, it makes me think you have sleep apnea. There are two forms of sleep apnea, one is obstructive (throat issue) and the other is central (brain issue). You should ask your doctor for a sleep study.
What youâre describing to me sounds like classical melatonin brain-fog, unrestful sleep, headache the day after.
Always start with the smallest dose thatâll put you under. DO NOT take a second (or more) dose if you wake up, or if you miss that chance to sleep, eg, by trying to stay up past when it hits. Else what happens after is exactly what you describe.
Think of a starterâs gun in a race. He shoots it to start the race, and thatâs it. He doesnât keep shooting, reloading, and shooting some more, once everyoneâs running on the track, let alone after everyone crosses the finish-line.
Thatâs all you need, to get to sleep. It resets your bodyâs clock to say, âOkay, sleep nowâ, and thatâs it. One and done. Hit it and quit it.
Thatâs why I said melatonin puts you under, and NicOH (or NicNH2, etc.) keeps you under. Melatonin is not a sleeping pill. Itâs only that starterâs gun that indicates, âReady⌠set⌠sleep!â.
Frankly, I think itâs misusing or at least misunderstanding melatonin that gives it a bad rep. âDoesnât work for meâ, âGives me a headache the day afterâ, etc. And that âtime-released melatoninâ should be outright banned, âcause thatâs not what itâs for.
Oh yeh, I was gonna add⌠look into ânon-24â. If your â24hr cycleâ, well, isnât, then you might naturally want or need, say, a 31hr cycle. So you canât fall asleep early enough, force yourself to wake up âearlyâ, then almost collapse from lack of sleep at inopportune times, etc.
