Linear driver + low Vf leds : SST20-DR has a Vf arround 1.6V at 3A according to the datasheet, let’s say that a charged cell drops to 3.8V at 9A, you’re dissipating (3.8-1.6)x9= 19.8W in the mosfet(s), which is enormous and the temp sensor in the MCU will pick that heat very quickly (thankfully because otherwise the mosfet would probably blow). Increasing thermal dissipation could maybe help (slightly), adding a thermal pad between the mosfet(s) and the body for example.
My bad, I totally misread the datasheet, the graph is deltaVf from Vf at 700mA, actually it say +1.6V on top of 2.35V so 3.95V. So there shouldn’t be any heating issue…
Then let’s say cell dropped at 9A to 4.0V, 4.0-3.95=0.05V*9A = 0.45W ironically linear driver friendly.
Of course mosfet has it’s own RDSon, there is a sense resistor, etc, so maybe 3.9V might be more realistic than 4.0V at 9A
In some Intl Outdoor threads I’ve seen posts talking about possible headlamps. Now is that something that Hank has actually considered or is it strictly a want from the community?
I hate have to report here, but I feel that Hank’s business is having trouble with keeping QA as tight as it used to be with the massively increased demand.
I now have 2 KR4 Ti that randomly turn on when screwing in the tailcap, one even initiates ramp config during tailcap screwdown if I don’t screw the cap on very slowly.
I’ll look the other her way for now, as the other nearly 30 lights have been pretty close to perfect.
Hank, if you have a chance to read this thread anytime soon, please also check your quality control with the D18 flashlight. Just before the K9.3 I also ordered another D18 (sand, SST20-DR) from you.
First of all, the D18 is absolutely awesome, making an insanely bright wall of deep red light. But the battery tube has so many sharp edges inside, it damaged two of three of my Samsung 29E batteries after using them for only one quick test. These batteries now have deep scratches or scraped areas. :-(
Thanks for checking. The Flashoholic tested his K9.3 and confirmed the same bug. I suppose it must be a firmware bug in K9.3 only. I am not sure when ToyKeeper will be back to investigate the problem. In the meantime I can only recommend to not using the faulty AUX Beacon light mode if you use the electronic lockout.
Luckily, it’s easy to physically lock out this light with a quick quarter turn of the tail cap. On lights where this is possible (non tail e-switch lights with anodized threads) I usually use this method simply because it’s faster. You lose the aux lights though.
+1 please. But I have a good feeling their output is less. I remember seeing the claimed lumens on the e21a d4 at 1200 lumens, I seem to remember hanks site saying the 219 b/c was higher ?
In the K9.3 at the top of the ramp (9A) the E21A is probably 20-25% less output but better spectrum (higher CRI) and better tint (below/near BBL). Even if the LED is more throwy by itself it wont be in a light because they generally use wide lenses for E21A to make the beam nicer.
If you consider the 219C may also be able to go into direct drive or partial FET then the difference in output will be greater.
Most of my KR’s behave like this if I don’t carefully hold them very straight while reassembling them. To avoid this, I’ve started just slightly loosening the head while screwing the tail on, and then retightening the head.
Hmmm, I have 12 KR4s but only had issues with two of the latest Tis. I was going to sand the inner tubes this evening to hopefully rectify the issue. I’ll report the results later.*
EDITSanding the tube made no difference. It was actually pretty smooth to begin with. Heavily lubing the threads kind of helped, for a couple screwdowns, issue still persists.
What causes this problem? It makes me dislike the lights with this issue tremendously. I won’t even use them. I didn’t buy about 30 Hanklights this year because they’re janky, flaky and fiddly, but because of the opposite.
I recieved my d4v2 and made a video reivew about and you can see both the optic shipped and the extra floody optic i purchases are different. Emisar D4v2 All Copper E21A nichia 3500k overview this is the thread for the video and my thoughts. I do have one question as i noted in the video. when I set my floor to lowest, when I ramp from low to high and then high to low it turns off the leds completely but keeps my aux lights on in the e switch. is this normal in the aunduril softwar for this light? Also I noticed I do not have memory mode as the light when clicked once will come back on in step 2 of the stepped ramp configuration default. thanks!
