How long do you sleep per night
If melatonin works for you, great! I’ve tried 2.5mg, 5mg, and 10mg melatonin… zero effect. (Maybe a slight headache with 10mg sometimes, though that might just be my imagination.)
Someone else I know, can take 5mg melatonin and be out within minutes.
I suppose it all depends what the underlying cause of insomnia is, and how your body reacts to melatonin.
Other things to try: OTC sleep drugs containing diphenhydramine, or just take Gravol (or generic), it’s the same thing and a lot cheaper. It seems to make most people drowsy. Hit & miss, IMO, but it’s worth a try. I find that if it works, it works well; if it doesn’t work, it makes the night awful.
After that, you pretty-much have to get a prescription for something stronger. There will be some prescription drugs that will work (it probably will not be the first one you try), but they come with more serious issues of dependency.
Non-drug approaches are various behavior-modification therapies. Most is common-sense, but for people without common-sense it can help a lot, and it has no down-side.
Stay away from psuedo-scientific nonsense, or “ancient Chinese” medicine. All those new-age things will do is take your money.
Finally, be aware that not everyone needs 8 hours of sleep. Some people can be perfectly fine with 6 hours or even less. If you wake up after 5 hours of sleep and feel wide awake, just get up and enjoy the extra 3 hours of free time that day!
I’ve struggled getting a good night sleep most of my life, and hate taking meds too. So I found a combo of things that all together, can get me a good night sleep quite often, which is a miracle.
I highly recommend trying them all for a week before you give up.
  1. This was the first step for me, it will probably be the last step for you… A doctor finally ordered a sleep-study for me years ago, and we discovered I also had severe sleep apnea. It’s like snoring, except you just don’t get enough air, leading to you (unknowingly) staying partially awake all night. You would thing you would figure it out, but you don’t. My wife didn’t even notice. So they ‘prescribed’ me a CPAP. It’s a fan and mask thing that uses room air to simply push back against your breathing and keep the airways open further. It sucks to need, but is totally worth the deeper sleep.
2) Low lighting after 6pm. I now have indirect LED strip in all rooms, but a good life-hack for you is to just shut off the light in the room you are in… and instead turn on the light in the room next door. The flood of light coming through the doorway is plenty once your eyes adjust. Also after 6pm, use the settings on your PC and phone to dim the backlight very low. I go to 8% brightness.
3) All the crap you have already been told, establish a schedule and stick to it, don’t drink caffeine after 6pm, blah blah.
4) An hour before bed, lower the thermostat 2 degrees F for the night. Being warm and cozy does help me fall asleep, but it’s not worth the poor sleep I get later. This trick works because your body can regulate it’s temperature without waking your mind. It simply increases or decreases blood flow to a cool arm or leg, instead of waking your mind half-way to deal with the covers. Typically I just leave one foot exposed to cool air.
5) 30 minutes before bed I take 2 Luna pills. They are almost identical to the cheaper Sleep aid from Walmart, but for some unfortunate reason, the expensive Luna works much better, and with only 6mg of Melatonin instead of 10.
6) Honey Nut Cheerios. I don’t know why, but it really helps me sleep.
7) Relaxation breathing. At this point I am in bed, but often can tell I am not melting into the mattress properly. So I breathe deep, then slowly let it out while focusing on a muscle group to relax. Then repeat with another muscle group.
8) Never go to bed owning Bitcoin.
about 9 hours each night during WFH
From 5h to 7h most of the days, and sometimes a little more on the weekend! When I can, I surely stay more time in the bed at least :slight_smile:
However, there were some years in which I slept less than 6 constantly…
If I’m lucky I get 5-6 hours sleep, but usually this is broken. At worse 0 hours, even with co-codamol. I can be in pain all day and as long as I’m busy it doesn’t bother me, but as soon as I try to sleep its there.
Seriously? It’s the most common anti-histamine there is. On the shelf of just about every store, in one brand or another. For allergies, motion-sickness, and sleep. I live in a nanny state too, but I hope it doesn’t get that bad.
Then again, there is other stuff I have to order from the US, because we can’t get it here any more. Try Ebay to see if you can get it that way.
Well, it’s only illegal if you’re caught. :wink:
People must be pretty desperate if they’re using Gravol to get high.
Which nanny state? Surely one of the dumber ones.
Getting high on diphenhydramine wouldn’t be pleasant. Even small amounts causes disturbing effects for me. It’s a deliriant.
Doesn’t sound like insomnia is your problem. You’re getting plenty of sleep.
When you describe brain fog and say you slept 8 hours and it didn’t feel restful, it makes me think you have sleep apnea. There are two forms of sleep apnea, one is obstructive (throat issue) and the other is central (brain issue). You should ask your doctor for a sleep study.
What you’re describing to me sounds like classical melatonin brain-fog, unrestful sleep, headache the day after.
Always start with the smallest dose that’ll put you under. DO NOT take a second (or more) dose if you wake up, or if you miss that chance to sleep, eg, by trying to stay up past when it hits. Else what happens after is exactly what you describe.
Think of a starter’s gun in a race. He shoots it to start the race, and that’s it. He doesn’t keep shooting, reloading, and shooting some more, once everyone’s running on the track, let alone after everyone crosses the finish-line.
That’s all you need, to get to sleep. It resets your body’s clock to say, “Okay, sleep now”, and that’s it. One and done. Hit it and quit it.
That’s why I said melatonin puts you under, and NicOH (or NicNH2, etc.) keeps you under. Melatonin is not a sleeping pill. It’s only that starter’s gun that indicates, “Ready… set… sleep!”.
Frankly, I think it’s misusing or at least misunderstanding melatonin that gives it a bad rep. “Doesn’t work for me”, “Gives me a headache the day after”, etc. And that “time-released melatonin” should be outright banned, ’cause that’s not what it’s for.
Oh yeh, I was gonna add… look into “non-24”. If your “24hr cycle”, well, isn’t, then you might naturally want or need, say, a 31hr cycle. So you can’t fall asleep early enough, force yourself to wake up “early”, then almost collapse from lack of sleep at inopportune times, etc.
Regular melatonin makes me sleep for just a short while, then I wake up.
Time-released melatonin works great for me.
No eerie effects the day after?? Wow…
Not for me.
That’s almost exactly what I told my doctor when he recommended a sleep study. I said I have had sleeping issues my whole life, from back when I was a kid and long before my weight was not ideal. I knew my weight issues was because of the sleep issue… A poor night’s sleep just makes me less active and need to snack more.
Statistically, 1 in 4 people have sleep apnea. It’s more common that I ever realized.
I used to have sleep apnea.
I don't anymore according to my latest sleep study (probably because I lost some weight), but I do sleep quite well with a CPAP machine.
I have a doctor's appointment in a couple of months.
I'm going to ask if any of my meds make me sleep excessively.
I think my psych meds might be the culprit.
Whatever melatonin is supposed to do, it has zero effect on me. No sleepiness, no side-effects, nothing the next day. I’ve tried it many, many times, using different dosages and taking it at different times. The only thing it might do, is give me a slight headache if I take 10mg of it.
All that stuff tastes bad.
Just roll it up in some cheese and stick it in your mouth. That’s what I used to do with my dog. :laughing:
btw, that too is classic sleep apnea. The sweating is a hint to the suffocation that woke you up, but you won’t recall it. The dreams are your body attempting process the experience in a way that keeps you asleep, but it ultimately fails and you wake up sweating.
