Flashoholic, can you please check if your K9.3 has the same software bug that mine has?
https://budgetlightforum.com/t/-/57210/2599
In order to test, please do the following:
1. From OFF, 4C to lock the light
2. In Lockout mode, 7C until you get to the Blink/Beacon AUX mode
3. Select any from the fixed colors (red or yellow or green...) via 7H
Expected behavior:
Beacon keeps blinking indefinitely until stopped by 4C. 1C or 1H should only temporarily activate Moon/Low mode until you release the button.
Actual behaviour:
Beacon blinks in a random duration (sometimes only 3x, sometimes more) and then stops. When it stopped blinking the Lockout mode is left and the flashlight will be turned on via 1C.
I made a video of the faulty AUX mode:
Thank you for testing!
