I received my SP35 about a week ago and have been playing around with it. Overall, I really like it! My review is up here
Pretty much everything I’m seeing is inline with what Funtastic has mentioned so far. The only exception is either I have an updated reflector or I’m less sensitive to the beam, one of the two.
Got mine today, but I am very disappointed!
With a full Molicel P42A mine barely reaches 5.4 A at turnon (tested with several cells and even VTC6, despite them not fitting…).
And it has only 21 kcd which is way below the 27.5 kcd that were promised…
That seems way off - is my flashlight defective or did you guys get similar results?
Hmm, I measured 24,250 cd which is just a little below spec. With regards to the amp draw, remember this is a buck driver, not a FET. Instead of burning of excess voltage, it trades volts:amps. You may be seeing 5.4A at the tail, but it’s likely still delivering 6 amps to the LED because of the buck.
Probably very little, the reflectors can’t be very different in dimensions, the emitter is the exact same and is driven to basically the same level (maybe a bit less even).
It looks like they’ll also be stocking it at Amazon eventually (non-aff link). I bought mine through Amazon; it shipped from China and arrived relatively quickly. Good pricing on the one directly from Sofirn’s website. When I buy stuff there, it usually arrives within a couple weeks - pretty fast for China shipping.
Does your SP35 beam look more like the one on the left or the right?
Left side beamshot is an “early batch” SP35, probably belonging to the 1st 100pcs.
Right side beamshot is a bit newer SP35.
(both shots taken at same camera setting: 1/10th second shutter speed, daylight white balance, ISO-800)
I’m guessing that, as a dealer early in the queue, and provided with a preview unit, Funtastic received one with the original reflector with the larger but inconsistent spill (“left”).
The beamshots in gchart’s review resemble the one of the right with the newer reflector, with a more clearly defined hot spot, less spill, and better uniformity.
It would be nice if Sofirn were to provide some official clarity on which version one would ship if ordering now. The sales figures on their stores (~150+ sold) would suggest that the early batch has been exhausted, but that would only apply if they don’t commingle the two versions in stock, with each shipment a random draw, and a lottery for the customer.
Something that hasn’t been mentioned here, but on TLF, are plans for a 35T, with a tail switch.
With the old reflector the transition from spot to spill is not that smooth and looks rather unpleasant. Also you get a very noticeable green ring around the spot, which you can notice in the comparison shots above.
At low to mid brightness the “corona/ring” surrounding the hotspot does look a bit greenish too on my early SP35 unit.
I suppose Sofirn can send updated reflector when requested.
I asked for a new reflector for SP31v2.0, since the ones I got had a ‘humid’ reflector (and reflectors can’t be wiped). Sofirn sent a new SP31v2.0 reflector after I requested (had to remind a few times)…
SP31v2.0 with “humid” reflector vs one that has been replaced with a newly sent reflector
